R56 Vehicle speed sensor A location
Can somebody with the correct knowledge tell me where the vehicle speed sensor a is on an r56? I tried Google, forum search bars, you tube but apparently I'm the only dumb *** that seems to have come across this trouble code (p0502 vssA) abs light, cel, brake light illuminated, with all the power of the web at my fingertips tips I can't even find a diffenitive answered I keep finding a bunch of trash threads that get side tracked from the original question, so you have to read through a bunch of worthless replys hoping you find some info and never even do, and info that contradicts each other, I can't stand working on cars any more, I can never find an answer to questions that should have been answered long before I even had this issue, I just can't help but vent my frustration in vehicle diagnostics let alone component locations. Like am I the only moron who ever wondered where vss a is located??
As far as I know, the car uses the wheel ABS sensors for vehicle speed reporting. If you also have an illuminated ABS light and Brake light, I would surmise that one of your wheel speed sensors is faulting. You’ll need to get your hands on a BMW/Mini code reader to find the specific code for the fault. That code will tell you which sensor is not right.
I use the Carly app to read DTCs, since it also does some coding functions:
https://www.mycarly.com
But for a dedicated scanner, you’ll need something like this:
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
ECSTuning (08-31-2022)
I decided to pull the wheels off and check the sensors and connectors for any visual signs of problems, noticed that the front two speed sensors where caked up with a little bit of grease/dirt after removing them from the knuckle . I decided to clean them up with some brake cleaner and reinstall and see what happens, been driving a few days and the code cleard itself and the abs and brake lamp indicators are gone, so if any one happens to run into this problem check your sensors and make sure they are clean.
Russter500
14
07-25-2023 05:52 PM
