R56 Defenders of Speed Intake Template
Hi, When I installed mine I found someone else's install pictures and used them as a guide.
there were enough reference points to get close. I started small and reamed the hole until the seal and housing fit correctly.
the hole was larger than I expected to install the seal in the firewall and fit the intake.
If you send me (PM) an email address I can send you the pictures I used and of mine installed.
airbusA346 (09-08-2022)
bugeye1031 (09-28-2022)
I still have the full instructions uploaded at the link below. It has 2 sets of measurements depending on which model you have.
http://www.chrunck.com/mini/dos_inta...20(lo-res).pdf
Just seen there has been extra replies on here... no email notifications even though instant notification is turned on.
All received...
I've got the K&N Apollo version... just having fun with the Alta aluminium intake pipe that came with the intake at the moment... looks like I've been supplied with the JCW version and I have an S so the turbo inlet is smaller.
Alta suggested either sleeving the turbo or fitting a JCW turbo. The joys of using American parts brought in Germany and being fitted to a UK based car.
Very curious of where did you manage to find this intake. i thought DOS is closed and you cant find one anymore
There are 2 versions?
V1= Straight pipe filter
V2= Curved and sits where AEM goes
Any idead if which of those two performs better?I guess V2?
is there any source i can find any?
Thank you
Thank you
After many months of work... upgrades since September include:
- TVT JCW Spec Turbo
- Wagner Tuning Competition Intercooler
- Schirra/DOS Intake
- Alta Performance Aluminium Intake Tube
- Full MotorTek Aluminium/Silicone Boost Pipes (Resonator Deleted)
- MTC Motorsport Noise Maker Delete Pipe
- GFB DV+
- MotorTek Aluminium Crossover Water Pipe
- MTC Motorsport Silicone Coolant Lines
- HEL Performance Braided Oil Feed Line (with Firesleeve)
- GT Tuning Oil Catch Can
- Aluminium Oil Filter Housing
- NGK ILKR8E6 Laser Iridium Spark Plugs
- Liqui Moly Leichtlauf High Tech 5W40 Engine Oil
- GFB DV+
DIRTY from Upstate NY
05-31-2016 04:18 AM
bdr127
10-19-2010 03:47 PM
