R56 Upgrading Head, bent valves
Believe I bent some valves. Needing some advice on what I should go with. 11 JCW with N14. Was in the middle of a stage 2+ with Lou when I spun the crank bolt. Running methanol injection. Going to rebuild the head and I've been looking and it seems like there is only a few options for valves and parts for it. Mainly from Supertech. It seems like I could either go stock, or Supertech. Does anyone have any experience with them or any other suggestions that I should be looking at? Do you think stock is sufficient for my build? Not looking to do Camshafts at the moment. Sticking with stock there.
Thank you
Thank you
Did you replace the guides or anything? I see there is brass and looks like steel too. Just curious what everyone is doing. I thought steel went away a long time ago?
I'm taking the head to a BMW specified shop where all they do is BMW and Mini. So I'm hoping they know what they are doing and are familiar with this altogether. But I'll keep that advice in mind. Thank you
I can't remember if the shop replaced the guides, but a good shop will check them and replace them if they are out of spec. In my case, I know they replaced all the valves, valve stem seals, and all the springs checked good. They also took .004" off the deck.
Keep in mind you will have to strip the head down before you take it to the machine shop, and then reassemble it when you get it back.
Ok, thank you for all the information.
Did you have it cleaned as well? When you say to strip it, you mean just the cams right? Leaving the valves and springs intact. Did you supply them the valves and seals? Do you have a rough estimate on cost for the machine work? Why did you have them deck it? I feel that may be unnecessary. Sorry for all the questions! I'm used to old chevys and LS motors lol
Maybe take a look at Thumper Heads?
https://www.thumperheads.com/
I had aTPR1 on a R53, ran great.
And I have about ~2 weeks on a N14 head I had him refurb/port.
So far runs strong.
So far runs strong.
So far runs strong.
So far runs strong.
I have just started down the slippery slope ....
The head is all I have done so far.
I went with the base option on the head, tpr1.
Picked the car up as a non runner, slipped timing.
no bent valves.
On the r53 had the tpr1 head, adjustable cam sprocket, downpipe, ic, sc pulley, intake, dyno tune, etc ...
Ran really nice.
no bent valves.
Ran really nice.
no bent valves.
Ran really nice.
no bent valves.
Ran really nice.
The core charge is if you want to use one of the heads he has on hand for quicker turn around and then you send your head in as the core.
I wasn't in a hurry so I just sent him my head, cost me about 110$ to ship from Colorado.
I didn't add any options.
When I got the head back it had TRP1 stamped on it.
So making the assumption the 1695$ is the TPR1
He is very nice and knowledgeable.
Usually responded to my questions within a couple of hours.
Drivetrain 250bhp with stock head...........
Paul Webster
07-20-2008 05:59 AM
