R56 Sport Mode Fail
Sport Mode Fail
Put my 13 S in Sport mode today and stomped on it. It sputtered and popped and went into reduced power mode and I got a low tire pressure message! After shutting down shopping and restarting the low power mode cleared. When I got home I checked the tires and they were all at 29 - 30. Aired them up and it cleared the tire warning. Now Im afraid to use Sport Mode. Does it do that if tires are low? Or is this an unrelated problem. I will hook up the scanner tonight and check for codes. It had always started popping on decel after running Sport mode for about 5 min.but ran fine until this incident. Running fine now but have not tried Sport mode again. Any thoughts are welcome!
I just did all four with BavAuto Coils. Once one goes bad the next will go bad soon on the OEM ones. Heat cycles kill the life on the OEM ones. Keeping an extra one on hand helps. Most VW guys replace them like oil changes, its a bigger problem on that side.
clintmeister
09-20-2023 05:21 AM
hp79
11-29-2018 05:27 AM
coreygo
06-22-2009 08:19 AM
