R56 2013 Cooper S Battery Not Charging.
Old 11-28-2022, 09:21 AM
RickR's Avatar
RickR
RickR is offline
Ok, I opened the bleeder screw, started the engine with the coolant cap off and coolant began to come out. Let the expansion tank run down a couple inches then refilled it. Repeated this 3 or 4 times then tightened the bleeder screw, put the cap back on and test drove it. It overheated again. When it was overheated no coolant was leaking out. The coolant level had risen to the top of the expansion tank and there was a faint hissing coming from the cap. Now I'm at a loss because it was not overheating before I took it apart to replace the alternator.
  #27
Old 11-28-2022, 01:34 PM
RickR's Avatar
RickR
RickR is offline
So I decided to check the water pump and it turns out I didn't replace the little **** you pull to relieve the pressure on the belt. Rookie mistake! All is fine now. Engine cooling properly.
  #28
Old 11-29-2022, 05:05 AM
DogfaceSGM's Avatar
DogfaceSGM
DogfaceSGM is online now
Glad you found the issue. Everyone oopses now and then.
  #29
Old 11-29-2022, 10:27 AM
bagwell's Avatar
bagwell
bagwell is offline
glad you got it fixed
  #30
Old 11-30-2022, 01:55 AM
Vanski's Avatar
Vanski
Vanski is offline
@RickR
Yay…….glad you found the issue
Jordan Smythe
01-09-2022 01:46 PM
heemskn
06-21-2021 06:43 AM
alistaircookie
09-07-2019 09:22 AM
krlambrych@yahoo.com
R60/R61 Stock Problems/Issues
06-29-2019 07:40 PM
genik
06-26-2014 07:35 AM
Quick Reply: R56 2013 Cooper S Battery Not Charging.
