R56 Coolant Pipe Upgrades
I haven't done it but, I have the parts to replace the one on the coolant tank. I am tired of sucking out anti-freeze to do an oil change so I purchaed a Tee to put in with a valve on the bottom, a hose extending to the bottom of the car to dump the antifreeze before I do an oil change. I was tired of always spilling some when I removed the coolant tank.
Everything I am using was found at Lowe's and is designed for hot water setups. I would have to check it but I think 350 degrees. Most of it is brass also.
BTW, did you get the entire silicone hose kit? I have considered one on E-bay but haven't pulled the trigger on it.
I've found the bottom fitting will sometimes leak a few drops of coolant while you're manipulating the tank, but it won't keep leaking once you put it back in place.
The following 2 users liked this post by Gubi:
bugeye1031 (10-16-2022),
Northern (10-15-2022)
I triied it that way once. There just isn't enough room for my hand and the filter coming out or going in. Much easier removing it. Thanks for the suggestion though.
BTW, this is the kit I am considering.
https://www.ebay.com/itm/30426733896...Cclp%3A2047675
HAMnMINI (02-28-2024)
I'm sure most of the hose kits sold in the UK are a maximum of 8 hoses.
The MINI parts diagrams only show 8 hoses, so which other hoses are being changed?
Shame no one makes a metal thermostat housing and aux water pump. I've also go an aluminium crossover pipe to be fitted too.
Yes, bend the coolant tank right up to the point where the plastic on the T feeding it is brittle after years of heating and cooling, then the damn thing snaps. Coolant all over the place, and you have to buy the molded piece that goes all the way to the turbo.
'Now I take the the Air box off and the air intake tube from the front and get at the filter that way.
Cheers!
Dan
Cheers!
Dan
The following 2 users liked this post by navwizard:
HAMnMINI (02-28-2024),
joseph.pokorski@gmail.com (10-18-2022)
That coolant overflow tank has a quick release fitting on the bottom. Syphon out the fluid into a clean bucket, remove the holding screw, pop it back to remove the quick release fitting, and pull the tank out. When done, pour the fluid back in, and top up if needed. It makes getting the oil filter out TREMENDOUSLY easier.
Kelloinc
R55 :: Clubman Talk (2008+)
08-10-2019 11:56 AM
