R56 Mini One R56 N14 engine swap (non-s to s)?
Hi all,
This is my first post in the forum after owning my 2010 Mini R56 for just over a year as a first car. In this time, I’ve thoroughly enjoyed the 1.6L mini and have had great help from these forums in odd repairs and modifications.
I come to the forum now as my N14 non-s engine is looking, and sounding, on its last limbs at 131k miles, and am looking to swap it out for a new, lower mileage engine for cheap. I am looking for that extra “oomf” the s will give. Rebuilding and adding a turbo would be too costly and so am wondering what the next best thing to do is.
Am I right in thinking the other engines such as N18 will fit? As many of the others here have, I too have fallen into the mini pit. I want to swap the engine out instead of buying a new car due to the amount of time and effort put into my current mini. I also like the idea of a sleeper build.
BUT, has anyone done this? Are there many complications regarding ECU, engine harness, etc? Should I buy a N14 or N18, with single to double vanos in mind? I’m keen to learn as much as possible regarding the swap, and your opinions and assistance would be greatly appreciated.
Bobby_Skywalker (03-15-2024)
Hi all,
Couple things - if you are driving a non-S, then you don't have an N14. We don't have the MINI One in the states, but I believe they use a detuned version of the N12 motor. N14 and N18 engines are designed to use a turbo, so I don't think you want to go that route because your transmission, suspension, mounts etc were designed to withstand a certain amount of power that you'd need to do major modifications on to drive with a turbo charged N14 or N18. Have you considered getting a tune specific to the engine you have? If you really need a new engine, I"ve seen people do N12 to N16 (non turbo) swaps, but you might consider your money just as well spent with getting your own engine rebuilt + a tune + upgrades to the brakes and suspension. Or sell the one you have and upgrade to a Cooper or Cooper S.
this is my engine, in the uk:
wondering if the n16 s will be a relatively easy swap; will it be plug and play, what parts will I NEED to replace and order?
I'm still not sure what you mean when you say non-S to S. The main difference in the R56 generation between non-S engines and S engines is the presence of a turbocharger. If you aren't planning to add a turbocharger, then getting an engine designed for one (N14 or N18) doesn't really make sense, plus they are probably going to be more expensive than getting a naturally aspirated N12 or N16.
Cooper (non-S) Mini One R56 N14 engine swap (non-s to s)?
Rolfeyyy14
Cooper (non S)
11-30-2022 06:34 PM
