R56 Rear hatch not opening
2009 R56 S
117,000ish miles
Sunroof
6-speed
So I've had some random unlatching issues. I have replaced both the trunk latch and the release button from ECS. I didn't think the button had anything to do with it but wanted to replace some wiring the previous owner did. There is no manual release under the rear seat.
The open hatch button on the key fobs used to work. Now they do not and I'm not sure why.
What can I troubleshoot get the trunk release to work?
I did find out that the purple / yellow wire also goes to ground, not sure if it should be or not.
So before I install a button to supply +12vdc to the gray / green wire what else can I do?
Thank you
117,000ish miles
Sunroof
6-speed
Thank you
Yes, its right here
https://www.northamericanmotoring.co...ing-o-diy.html
Check the herness side as its sounds like something was messed with. Check the pinouts on main harness going into the trunk lid and the latch under the rear lower trim that connects to the latch.
Mike
Mike
R50/53 Rear hatch latch question
a1machinista1
01-10-2018 01:16 PM
