R56 Start/Stop Bouton
https://www.northamericanmotoring.co...-position.html
Based off what i know it will have to be flashed at the dealership after install or it will not read.
Make sure it inserts and locks in position.
Quote " I changed mine, no coding needed. It's literally just switches, no brains."
Call the dealer and i believe its 1 hour, dependent on dealer hour rate can very. I have seen dealers charge $100.00 and up.
Can you start the car at all? I would drive the car there and then have them install and flash. That's the only other way you can do it.
Ok do you have a manual transmission and check the clutch pedal switch like in the post i shared?
Oh its stuck in the slot, did you try the push in and pull out method. To try to unjam the socket reader. You have to push the key in with some force then pull out.
convict1
Metroplex MINI - Texas
11-27-2010 01:50 PM
AC_MINI
10-05-2003 12:45 AM
