R56 Koni Active Not Seating Into Knuckle
I am at my wit's end, trying to seat the front strut into the steering knuckle on the passenger side. The driver's side went in without a problem. The passenger side knuckle slides up the strut fine until the last 1/8" when one edge of the knuckle touches the lip of the strut before being fully seated. The result is a small ridge inside the pinch bolt hole that prevents the bolt from passing through. I have tried smacking the knuckle with a dead blow hammer from all angles. Wiggling and cursing at it does nothing as well. I have slid it back down and tried 3x more, and each time the same point of contact prevents me from declaring the job done and grabbing a cold beer.
What else can I try? I have a spreader on the way, but doubtful that will help as the angle that the strut enters the knuckle, but only at the very tail end. Someone, please give me that magic tip to make this work.
this comment right here! Thank you! I used a punch to rest on the ridge and was able to tap the ridge down. You were right that the tab must have gotten caught outside the slot and bent up. Pinch bolt through and now I can wrap up the job. I’d buy you a beer if I could.
Mini_Binnie (06-25-2023)
luis_v
How To
06-22-2020 07:51 PM
ST3ALTHPSYCH0
Suspension
09-14-2017 04:11 PM
rescay
03-14-2012 05:47 AM
