R56 No 23v-337 Footwell Module Recall (FRM) Risk of Fire
Came up a month or so ago.
https://www.northamericanmotoring.co...-incoming.html
Looks to be a continuation of this one:
https://www.northamericanmotoring.co...le-recall.html
warranty extension that turned into a recall, thats my guess
Footwell Module has the main board, the relays are on the fuse box or SPEG/JBE module
https://www.ecstuning.com/Search/Sit...otwell_module/
Water gets to it from clogged sunroof drains. Or bad window seals, front seal on windshield, non sunroof. Or a convertible top down problems. Multiple ways for this to happen even on a non sunroof car. The problem is it too low in the floor and it was not made very waterproof.
Vanski (12-25-2023)
New units from what i can see, might be some other stuff added also as part of the fix.
bugeye1031 (07-18-2023)
Yikes, were you ok?
It happened while the car was parked in the garage, sometime between last Thursday and yesterday. I noticed the wipers and mirrors had gone up, which was odd. It seems like it had cooled off for at least a day because nothing was hot to the touch.
I was working on changing the brakes last week, so I could actually drive it again. On the bright side, I no longer have to deal with the damn rusted rotor set screw.
Update on the FRMs https://www.northamericanmotoring.co...utions-13.html
Yep, thats my guess also. Yep if you can get them to cover it, that's what i would do. My MINI is not covered, so if mine goes bad i got to buy one and its finally in stock.
