R56 Piston Oil Sprayers 2011 Mini Cooper Base
No oil sprayers
There were none but not sure if the previous person never put them in. I didn't see any threaded ports when I went into it again.
I am really new to minis and the forum, Is there a link to a service manual or engine build sheet? The block is sleeved back to stock but the new stock OEM Pistons seem small. Each bore is about 76.8mm and the Pistons are about 75.5mm. We need the gap spec for the rings and piston to wall clearance to make sure they are correct.
There is a rubber gasket that is used to seal that passage:
https://www.realoem.com/bmw/enUS/sho...diagId=11_4549
