R55 Central locking system and turn signal malfunction
Hi,
After jump-starting, the driver's door can no longer be unlocked with the central locking system, while all the other doors work fine. Additionally, the comfort turn signal feature only works about every 30 drives. So, it almost never works, but every once in a while, as if by magic, it does.
I have read about a defect in the FRM unit, but the description of the problem is usually clearer in those cases since more things are usually defective, like lights, etc. In my case, only part of the issues are present. Does it make sense to send the FRM unit for repair? Could this be the problem? How can I find out more about this, is there a way to "read" this out?
The same behavior occurs with both keys, and I can no longer access the menu for the comfort turn signal:
Thank You
Mini R55, built in 2008.
Thank You
It's likely that the jump start created a voltage spike that corrupted the FRM software.
Once the FRM software is reprogrammed, I would highly recommend that you make a habit of removing the 4 FRM fuses behind the passenger kick panel prior to either disconnecting, reconnecting, or jump starting the battery.
Navigation & Audio Any help with a JL Cleansweep issue?
jso123
06-14-2010 11:06 AM
accce
03-20-2008 10:17 AM
Littlesha
02-13-2008 02:16 PM
