R56 2010 cooper s 2e3c alternator code
07-02-2024, 03:16 PM
on
Anyone have and experience diagnosing a 2E3C alternator code on a 2010 cooper s? Any help would be appreciated.
07-02-2024, 03:28 PM
Symptoms?
Crank, no start?
07-02-2024, 03:31 PM
on
Quote:
Originally Posted by
Maybe, maybe not
Symptoms?
Crank, no start?
cranks and starts fine. Alternator’s putting out 14.1 - 14.2 volts
07-02-2024, 03:45 PM
2e3c is not an alternator fault code.
07-02-2024, 09:07 PM
on
Maybe, maybe not
07-02-2024, 09:16 PM
Your posted voltages do not reveal a charging issue, though you did not mention the test conditions.
If you clear 2E3C, does it return?
07-02-2024, 09:25 PM
on
Maybe, maybe not
yes. It clears and doesn’t return until I start the car again. New battery installed and coded and alternator was replaced about 12000 miles ago with OE alternator.
07-02-2024, 09:36 PM
Any voltage deviations under the three conditions shown in post #4.
07-03-2024, 05:09 AM
kstubbs77
How long after changing the alternator did the code start showing up?
https://bmwfault.codes/XMLDiagView?d...QANwA4ADAANAA=
Sounds to me like the alternator is the wrong amp size, and is putting too much voltage into the system.
07-03-2024, 09:35 AM
on
Maybe, maybe not
Did the test as described and had 12.2v with key off and maintained 14.4 volts throughout the test with car running.
07-03-2024, 10:01 AM
kstubbs77
It's not causing 2E3C, but your battery voltage is clearly too low. You should charge the battery.
Also do the other two tests while monitoring the system voltage in an attempt to expose a charging issue.
Y. A. Martin
06-25-2024 06:17 PM
dcantwell
01-20-2015 10:11 AM
MiniPanik
02-21-2014 06:09 AM
phil@detailersdomain
Detailing 101
09-30-2010 01:54 PM
