R56 Brake FLUID SPEC
Note that you're posting in the R56 forum so if you've got a 2019 you're in the wrong place.
That said, DOT 4 LV should be the right spec, yes. Pentosin DOT 4 LV will work fine but I like the Bosch ESI6 stuff: it's low viscosity, exceeds DOT 4 specs, and has a three-year replacement interval. It's relatively easy to find and not super expensive; I usually just buy it from Amazon.
https://www.boschautoparts.com/docum...id%20Flyer.pdf
Tires, Wheels & Brakes
12-15-2015 04:24 PM
