R56 Cooper s maf sensor wiring pinout
Would anyone know what the pinout on the wiring harness would be for the maf sensor? My scan tools are showing 0 g/s and wanted to confirm it's not a wiring issue before I buy a new one. The car runs, idles funny sometimes, no codes. 2011 Cooper S N18. Thanks!
Thank you! Pin 14, no luck. The other wires work fine. Not sure what's going on, odd that the wire would break/fail somewhere, is there another connector somewhere below that I'm missing? Gotta spend more time on it..... thanks for info!
Are you saying that no yellow wire exists at the pin 14 position?
As you can tell, the wiring diagram and connector pinout disagree about the location of the yellow wire. The wiring diagram shows the yellow wire at pin 18 of DME connector X60232, whereas the connector pinout table indicates that the yellow wire is at pin 14 of DME connector X60232.
View of female pin side of DME connectors A, B, & C.
I'm in Canada, I'll take a Pic tomorrow. Thanks!
mkov608
02-21-2024 02:04 PM
pollito
10-01-2022 08:36 AM
Russter500
10-19-2021 07:35 AM
