R56 2007 MCS Weight
Details are here: http://motoringfile.com/2006/08/14/o...pecifications/
The US method of measuring weight is a bit different so the numbers will change slightly for us in the US. However what the above article does is try to compare apples to apples by using the EU Unladen weight figures from both the R50/R53 and the R56.
Thanks Gabe,
I read your article on the weight. Where did the original guesstimate of 190 lbs come from?
The dealer just got this memo, official MINI USA letterhead, and it clearly states 2491 lbs for an R56 6MT US car. Would it be safe to assume that your source for the original article was using this same letter?
And, if so, are we now sure the sure is incorrect? I mean, the engine alone should account for 70 lbs, there's less glass, the exhaust is much simpler and therefor lighter.....
Obviously, I want to believe it. If the R56 is 2491lbs, performance should be close to JCW stock. If it's not, well, I've got to get my JCW order in =]!
Originally Posted by LannyMCS
Thanks Gabe,
on
Originally Posted by resmini
Even slightly less weight is great combined with more power, more torque and better gas mileage.
And headlights that won't wobble
eatsleepautox
10-30-2015 06:46 AM
fm.illuminatus
08-10-2015 12:15 AM
