R56 U.S. spec R56's sit too high???
I noticed all the R56's @ the Detroit show sat unusually high compared to their euro spec counterparts. I never recalled this being an issue w/ the R53???? Can anyone give an explanation for this??? It seems you can always expect a U.S. spec Euro car to get screwed up by distributors one way or another.
Another thing; Is the black bumper trim (wheel arches, etc.) of higher grade plastic than the R53??? I've heard there to be problems with discoloration on the R53. This may be just a general wear issue with all black plastic trim in general.
The Europeans also complain about the R56 ride height. The conclusion on MINI2 was that it looks higher than R50/R53 but physically it is not:
http://www.mini2.com/forum/2nd-gen-w...apointing.html
I have not heard or seen this at all yet. Granted it is an issue over time regardless of grade because uv degrades plastics over time. and I see a bunch of Z71's around that look like crap but this has not been the case on the R53
Nope. Not sure when, but the factory is switching over to a tighter spring setup similar to that of the Euro spec GTI. This is noted on VWVortex in the MKV GTI forum.
Anyway, I think even if they did raised the r56 it would be because a lot of people (mostly non-enthusiast) think that the r53 sits too low (in my experience, in the USA).
the MIni2 forum has already been linked by RKW. here is a shot from said forum, and again the suspension should take about a year to settle. H&R already has a set of lowering springs available so you are not without options
uuhhhhhh... foreshortening
with the perspective distortion the marked up photo does not prove much. The slope of the reference lines makes it appear that the R56 is taller. At the same time it makes it appear that the R53 is on higher ground, which it is not.
Yeah, but that would be about the Euro spec cars, not US right? I've also heard about the US spec GTIs being sprung higher then others (although I *think* they might have changed that for 07).
(Of course there will be aftermarket options if you are of the mind of doing that and handling the dealers when it comes to potential warranty work issues after you've swapped out the stock parts.)
what the picture is showing is that the R56 actually rides lower to the ground (true, i will search for the numbers) and the apparent height of the R56 is simply the fact that it has a higher beltline, the R56 is actually shorter (again will search for numbers) but you are right with so many comparison lines it can be distracting
Yep. Under those new/larger wheel arches, anything smaller than 17" wheels looks odd in stock trim.
Some H&Rs (or equivalant) and a move up to 18's would do much for the overall looks.
16, 17, or 18, they should not be changing your overall wheel+tire diameter - makes no difference to the wheel gap. A lot of people seem to like this lowered look with low profile tires. I think the R56 looks better with the meatier tires, 16s, perhaps wider than stock. Looks like a rally car, rather than a touring car.
