R56 To sunroof or not to sunroof ...
#77
#78
#79
#80
In my soon to arrive 2007, I originally was going to go sunroof, then didn't. I have an Accord with sunroof, and I might use it 5-10 times a year. What I didn't like about the mini sunroof is you can never block it out. I has a perforated sunshade, but you'll always have light flitering in whether or not you want it. In my accord I at least have a pull shade that totally blocks out the light when not desired. I went without sunroof, and glad I did.
#81
#82
#83
Here's an advantage of a sunroof that I don't remember seeing mentioned:
As you approach the car, if it is programmed this way, you can automatically open the windows and roof with the push button on the key before entering the car. Heat rises, and the car cools down considerably before you get in.
Zip
Zip
#85
#86
Wouldn't it be kinda cool if the rear section automatically tilted up at 60mph, like all the auto-spoiler cars do?
#87
#89
Daffodildeb
Re: "Hey--just in from the engineers in Germany--the sunroof weighs 51.9 LBS. I've got a great MA, eh? "
Is that a net weight? Is there a deduction for the roof section that is replaced by the sun roof? I still think it is worth some extra weight. Jan 28th and mine was open today.
Terry
Terry
#91
On the new models, what are the different positions the sunroof(S?) can be in? I know there's 2, and I understand they tilt independantly of each other, How do they open? How far do they open? The pictures I've seen don't make it easy for me to visualize how the glass slides open to open the top up more than a crack.
thanks in advance!
thanks in advance!
#92
#94
I'm surprised the concensus has been that the r50/53 sunroofs are so trouble free. It is not nearly as good of a sunroof as say a BMW one. The reason the headroom has remained is because the sunroof is a pop up and slide back type instead of a slide into the roof type (obviously).
What this also translates into is wind hitting the large sunroof that has been popped up into the air, the noise is nearly unbearable on the highway. This makes a wind deflector a very nice option. The sunroofs on my BMWs were always almost silent on the highway, making 75-80mph cruise comfortable and almost surreal. It is not even close to that in the MINI.
Both of my Cooper Ss an 03 and now an 06 have the sunroof and all 5 of the BMWs I have had always had sunroofs. If I order a new MINI it will almost definitely not have the sunroof. The roofs in both of mine squeeked and rattled. I distinctly remember getting very angry and POUNDING on the roof of my 03 trying to make it stop. Also, my 06 has had a wind whistle since new (noticed it at 35 miles on the drive home from the dealer) that has not been fixable which becomes extrememly annoying on a long highway drive with the roof closed.
One last thing I would consider after being in a rollover accident recently in another car, I don't think I would want a big hole that shattered out in the event of an accident.
I should also mention that I am super sensitive to noises like the hum a TV makes when the volume is off, flourescent lights, etc.
#95
I ordered my R56 without. I sort of like sun roofs and have them in most of the cars I've owned. But I find that I'm using them less now. Not sure why, but I don't. I plan on some autox and track days, so that was a reason to omit the sunroof. Weight up high is the worst thing to have. And if you are wearing a safety helmet, head room is already decreased.
If I want more sky I'll get an MR2 Spyder or Miata. If you like a sun roof, you will love a roadster!
waiting sucks,
Joe
waiting sucks,
Joe
#96
#98
I've had two MINI sunroofs over the past 4.5 years, and the only problem (with the first one) was a rattle that came from the pop-up plastic wind deflector things, which were rattling against the frame when the roof was closed. This was solved in two minutes by affixing some adhesive felt to the flaps.
I personally can't imagine my car without the sunroof. It significantly adds to my enjoyment of the car every single day, even when it's ten degrees outside. It's nice to have some extra light in the winter when it's so cold. It's not a big deal to me that I can't use it on the highway because of the noise; I probably wouldn't anyway, due to the decrease in fuel economy.
It may not be as good as a BMW sunroof, but it's not a Cavalier sunroof, either...
