R56 New turbo Mini S and turbo timer?
Really? Does the turbo cool by engine's oil? If so, after shutting off then
does the pump continue to run? I believe, some manufacture drain off
the oil from turbo when the engine is off. But for my Evo, the manual
says to cool off turbo with engine on after driving with full engine load
for an extended period of time.
From MINI's original press release about the Prince in Dec. 2004:
"To prevent excessive build-up of heat in the oil- and water-cooled turbocharger after the engine has been stopped, an additional electrical water pump starts automatically as soon as the car comes to a standstill, dissipating any excess thermal energy from the system."
It's in the last paragraph of the release.
http://www.motoringfile.com/2004/12/...ange_in_detail
On a side note, does that mean fittin Mini S with those tiny odyssey
batteries is probably not a good idea..
![tongue](https://www.northamericanmotoring.com/forums/images/smilies/tongue.gif)
I hear you there. DB from White Roof Radio was talking about his electric fan not shutting off after he powered down at the tire shop and it ran until the battery was discharged. Granted all things wear out, but if that was the sensor that tells the water to circ after shutoff, you'd soon have a turbo that's not getting it's after-spanking rubdown. Smart cars are cool, but the more tech we get the greater the chance for all this gear to kablooie. And unfortunately, this tech doesn't come with much fault tolerance. Just some fault sensors to rat out some of the bad components. My greatest fear with the Prince engine is that the "Smart" oil pump gets mentally challenged one day and results in a spun bearing.
09R56
11-16-2022 10:49 AM
Drivetrain removing heat shields for turbo cat ?
rckrzy1
08-11-2015 06:06 PM
Ambient Thermal Management
08-07-2015 12:27 PM
