R56 Any pictures of this?
I am leaning towards PW with a black hardtop and the black parallel sports strips in the configurator, not the traditional bonnet. The configurator says the strips are also in the back?. Is this to much?. Any pictures of the front and back out there. Thanks again for everbodys help.
I was curious also.
I believe the option you're referring to is on screen 5 in the miniusa.com configurator, sport stripes, $85 , "twin parallel white bonnet stripes up the front and rear end." Not clear to me if these are simply more stripes (up the back?), or if the bonnet stripes would look different than the standard bonnet stripes. But since these are available as a dealer installed item, not factory, the dealer should know.
I'm also curious about the bonnet stripes I've seen on some earlier versions, not the parallel stripes but lines that basically wrap around the bonnet scoop and go up each side of the bonnet - sort of one stripe that circles around the scoop rather than two totally separate parallel lines. I think that style is very nice, but don't see it as an option on the '07.
muddflapp
09-20-2015 03:55 PM
StrongIslandMini
09-19-2015 10:58 AM
Interior/Exterior Picture needed: rear seat pivot, side panel removed
keen
09-17-2015 12:06 PM
shahriar35
09-14-2015 11:53 PM
