I ordered my LEDs flexi strips from oznium.com
Wasn't that hard to install, just took some time. I have it tapped into the footwell lights, so they fade up and down with the lock/unlock, and tapped into cig lighter for constant power at hand. It all runs through a 3-way switch so I can select which one I want.
Oh and it is white light, not blueish like it came out in the pic
I'm with you. I saw them on the Launch edition car in the showroom. What I mean is I'm thinking I won't, as I'm beginning to be OK w/them and to keep the car uniquely a 'Factory JCW' look.
minim8o what type of processing are you doing on your photos. They look HDR. I am trying to work out HDRs but all my attempts have failed. I used CS3, the merge to HDR, and then play with the curves. What am I missing?
haha ... I just had that debate w/someone. I didn't think it was a HDR technique -- because I was only using one photo, not the normal 3 or more used in HDR that truely starts w/an increased dynamic range -- but he convinced me it was. Have a look in this thread from this post on for that discussion... (easier than re-writing all) I use Lightroom. I think you can use ACR or CS3 and the terminology carries.
Well they are attached to the frame thats right behind the bumper. There is a gap big enough for a fist to fit between the lights and the condenser. So far they are holding up fine. They are the flex strip LEDs that are covered in silicone
i would love some feed back. The new ones are after the interior shots.
Looking good! I can't tell if it was my monitor or not, but I felt like a lot of those shots could really benefit from a little higher exposure and/or saturation values. Then again, I tend to always increase the saturation on just about every picture. That little extra color just makes things pop.
