R56 Question about programming
I know you can program preferences by pressing the "ON/OFF" button with your foot off the clutch (or brake for automatics) to get to the radio ready mode. But are there other preferences that you can only program with the car running? Or can you program everything in the radio ready mode?
Not sure what you are asking, but the radio/cd/IPod/are programmed through the radio interface. Functions like running lights/locking are through the left hand column stalk. These require you to have your car running. In their wisdom MINI has spread the directions throughout the operators manual.
That is programmed through the "home" button and the Mini joystick by the gear shifter. From there you go to "Setup," "Settings," "Vehicle and tires" and "Lighting." There, you can switch on the triple turn signal and also program the car for daytime running lights, if desired.
Okay, now I'm confused. :impatient I thought this is programmed by the the left hand stalk. You press until you see "Set/Info", and hold until display changes and so on until you get to the two arrow symbol when you press and hold until "1X" "2X" or "3X" appears and you select which one you want. I totally am not familiar with the method you posted. Is that in the 2007 manual?
In my hard copy manual, the instructions I provided previously appear at the end of Page 46 and the beginning of Page 47. The online version shows only the instructions for the left hand stalk. It's located on page 40 of that manual.
By either method, though, the only choices are one or three flashes of the turn signals. No middle ground or the opportunity for dialing in a larger number.
Go to Page 39 in the Owners Manual "using turn signals." Start your car after inserting key fob. [COLOR="Red"]The remaining directions carry over on Page 40. MINI should rewrite some of the sections and give MAs additional training. Programming integrated radio and other features are too complex.
Go to Page 39 in the Owners Manual "using turn signals." Start your car after inserting key fob. [color="Red"]The remaining directions carry over on Page 40. MINI should rewrite some of the sections and give MAs additional training. Programming integrated radio and other features are too complex.
The car does not need to be running. I programmed everything on mine with the engine off.
The ignition needs to be on. Insert your key, and without pressing the clutch or brake, press the start/stop switch. You'll see the fuel guage, warning lights, etc... come on. You can then program to your heart's content.
R50/53 More supercharger hulabaloo
one73ronin
23
09-22-2015 09:56 AM
09-11-2015 01:15 PM
Manny_cooper
09-03-2015 05:48 AM
