R57 Auto dim Universal garage door opening rearview mirror
Hi gang,
Anyone out there with UGDO rearview mirror problems? We had one installed and the green LED light won't come to program. The dealer tested it and said that there is a problem with it, they don't know if there's a compatibility issue with the R57 and the mirror?! They are looking into it...it's been a week! Anyone w/ similar R57 issues!
I got mine programmed the day I took the car home. I got an VW Eos and this took 6 months to get programmed !
If you have a garage door with a rolling code, you need to push the the concerned button on the mirror at the same time as the garage receiver. Read more on homelink.com or at johnsoncontrols.com where everything is explained in detail. What I experience is that the mirror vibrates when driving !
Thanks stefspain, did your mirror come installed from the factory or did you have it switched out at the dealer? Ours was switched out at the dealers...they've ordered another wiring harness, it should be in next week. They will test it out on a model there when it comes in and let us know if it's a go.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
SoCalledFriend
08-06-2015 06:59 AM
