R57 2009 Mini Cooper Cabriolet Burned Tail Light Bulb
I have a R57 and haven't done this before - the little guy eating popcorn is a way to post and say that you're here to sit back and watch and follow the thread. By posting, I automatically get emails of updates. It's handy when someone else has a question that you want to also hear the answer to.
My daughter had a 2005 -- so it may be a little different, the first time she had one changed middle of winter, I sent her to the dealer -- $110.00 and took them over 2 hours, they were a new dealer, so I'm thinking they really didn't know how. She later had another one burn out and I changed it. Lay the backseat down, crawl through the drivers door and laydown, open the access panel, can't remember the wrench size, but you can remove the 2 nuts holding the assembly, they were also held on by a clip once you can get it pulled back you can change the bulb, took about 20 minutes. Good Luck
Typically, 1 or 2 screws and then the assembly comes off. Look for any screws directly behind the tail light. I don't know if this helps, but realOEM shows:
01LEFT REAR LIGHT, WHITE TURN INDICATOR
08/201063212757011$126.97
01RIGHT REAR LIGHT, WHITE TURN INDICATOR
08/201063212757012$126.97
02Bulb socketP21W3
08/201063212756177$6.60
03BULB YELLOW12V 21W3
08/201063217160791$5.58
04Bulb socket
08/201063212756178$8.78
For vehicles with
White direction indicator lights
S785A=Yes
05BULB SOCKET F YELLOW BULB
08/201063212756176$6.60
06Bulb silver12V 21W2
08/201063217160897$19.40
06Conversion kit, bulbs, silver
08/201063120420391
+core, ENDED
07Fillister head screw with collar
08/201063212755729$0.30
08Expanding nut
08/201063212756354$0.58
09Universal MPQ socket housing uncoded6 POL.2
08/201061136984758$3.12
only in conjunction with
--Socket contact ELO-Power 2,8x0,630,5-1,0 MM²?
08/201061138364832$0.35
--Socket contact ELO-Power 2,8x0,631,5-2,5 MM²2
08/201061138364834$0.35
--Socket contact ELO-Power 2,8x0,630,35-0,5 MM²2
08/201061138377162$0.35
10Bulb socket
08/201063212756179$30.57
02Bulb socketP21W3
04Bulb socket
For vehicles with
S785A=Yes
08/201063120420391
+core, ENDED
08Expanding nut
10Bulb socket
Hedjuk
09-13-2013 02:07 PM
