R57 Transmission mount replcement
Has anyone ever replaced a transmission mount on an R56 or R57? (see link below for part) I took my 2012 R57 to the dealer to get the fuel pump replaced and they mentioned my engine and transmission mounts were shot. I have found guides on how to replace the engine mounts but nothing on the trans mount. Can anyone offer any advice on how this is done? I hope to get the car on jack stands next weekend.
Thanks for the help
https://www.autohausaz.com/pn/LF-22316784355
Thanks for the help
I just did this last week, it really was not a difficult job at all. You'll need to place the car in front end service mode. After that it is pretty straight forward. The only real issue I ran into was working around and through the DME to get to the bolts underneath of it. Definitely disconnect the battery and remove the DME to avoid damaging it. My passenger side (engine) mount was totally floppy and way worse than the transmission mount. I would recommend replacing both mounts. Some of the bolts and the nuts on the mounts should be replaced.
I ordered the following from FCP Euro:
07119906050 x2
22116793713 x4
07119906051 x1
07119906187 x1
07119904575 x4
22116793735 x1
The hardware was around $50 shipped and arrived within a couple of days.
07119906050 x2
22116793713 x4
07119906051 x1
07119906187 x1
07119904575 x4
22116793735 x1
raverill (05-03-2020)
07119906050 x2
22116793713 x4
07119906051 x1
07119906187 x1
07119904575 x4
22116793735 x1
07119906050 x2
22116793713 x4
07119906051 x1
07119906187 x1
07119904575 x4
22116793735 x1
07119906050 x2
22116793713 x4
07119906051 x1
07119906187 x1
07119904575 x4
22116793735 x1
07119906050 x2
22116793713 x4
07119906051 x1
07119906187 x1
07119904575 x4
22116793735 x1
This was my passenger side mount. Totally gone lol. From what I understand, these should be replaced around 100K. Mine had 105k on it, but I drive it like I stole it and have a lot of other suspension mods that could have contributed to the failure. If you have the time and money, you should consider doing it DIY. It will certainly refresh the front end and make the car feel new again. Loose mounts cause excessive engine/gearbox movement and can cause all sorts of other issues. For me, it eventually caused my gearbox to not hold 6th gear at high RPM. Replacing the shifter box/bushings and eventually, the gearbox mount fixed this issue about 95% of the time. But I'll still need a new gearbox and it's probably because I didn't recognize that the mount was bad early on.
scotty_r56s (04-29-2020)
i have pulled these engines several times with trannys and i dont think you need to put the car in service mode...I just serviced my transmission replacing the internal filter and I did have to unbolt the trans mount...i took out the 3 bolts and lifted the engine to do my work. I believe i could have finish removing the mount if i wanted it. you do have to remove the ecu and unbolt the fuse box...then remove the mount which holds them.
MiniToBe (05-01-2020)
I have replaced several timing chains in the r56 and part of the step is to remove the passenger side upper motor mount. floor jack to lift the engine and then you can can go to town removing all the stuff to get to the motor mount. Very doable without service mode but ya cannot knock the extra room when working on these engine bays. everything is tight.
your thoughts on if the engine and transmission mount need to be replaced? This was my brake torque check
