R58 Insulation under hood
Old 04-01-2012, 01:17 PM
PatrickKB's Avatar
PatrickKB
PatrickKB is offline
My new coupe has insulation under the hood and I can not see the scoop it looks different from pictures that I have seen of other Mini's. My scoop and hood do not get hot to the touch after the engine has been running at all. Is this the new heat shield that I have read about?
Old 04-01-2012, 03:00 PM
Fly'n Brick's Avatar
Fly'n Brick
Fly'n Brick is online now
Since they replaced the SC with turbo, the scoop is just there for looks, non-functinal, and yes, insulation is there for heat. Turbos create a lot of that. Look back to some of the earlier threads about melting scoops when the turbo was first introduced.
Old 04-01-2012, 07:02 PM
Keysersozeh's Avatar
Keysersozeh
Keysersozeh is offline
Huh.. Mine doesn't have that. It's just bare metal.
Old 04-01-2012, 07:19 PM
boxter4ever's Avatar
boxter4ever
boxter4ever is offline
Same here?
Old 04-01-2012, 07:46 PM
indymidnight's Avatar
indymidnight
indymidnight is offline
Mine does... Wonder if it is just the S models with the newer engine?
Old 04-01-2012, 09:05 PM
Keysersozeh
but but but.. I want pretty black insulation under my hood.. :whine:
Old 04-01-2012, 09:12 PM
Fly'n Brick
Dang, gonna get that way about it, I'm gonna keep a closer eye on my co-pilot...
Old 04-01-2012, 11:37 PM
johnf36's Avatar
johnf36
johnf36 is offline
Hummm interesting, deserves some looking into.
Old 04-02-2012, 12:36 AM
clubsterUK's Avatar
clubsterUK
clubsterUK is offline
I'm sure the cover is just for diesels
Old 04-02-2012, 06:12 AM
rosvick's Avatar
rosvick
rosvick is offline
Actually, my Coupe S has the same insulation. I thought it had something to do with my car being Canadian?
Glad to hear this should keep the heat off the scoop!
Old 04-02-2012, 10:56 AM
ditc's Avatar
ditc
ditc is offline
My S Coupe has the insulation too. (week 5 build) US-spec.
Wonder why some of you guys dont?
Old 04-03-2012, 07:43 PM
DAVESTER's Avatar
DAVESTER
DAVESTER is offline
My S Coupe does not have the insulation--
Old 04-03-2012, 08:05 PM
rosvick's Avatar
rosvick
rosvick is offline
Could this have something to do with production date? Or perhaps climate (i.e., cold weather vs warm weather)? I'm pulling at straws here....
Old 04-04-2012, 04:59 AM
Xeraux's Avatar
Xeraux
Xeraux is offline
Hmmm... Mine has the insulation and a heat shield on the turbo, too.
Edit: I found out my production date was 1/2012. So... Dunno.
Old 04-04-2012, 06:15 AM
Fly'n Brick
Just another case of the haves and the have nots. Maybe it is time for an OCCUPY something or other.
Old 04-04-2012, 12:48 PM
pgrmstr's Avatar
pgrmstr
pgrmstr is offline
My JCW Coupe was built in mid Jan2012 and I have no insulation....and the scoop does allow air through...just no intercooler sitting under it to benefit but it flows air
Old 04-04-2012, 01:03 PM
johnf36's Avatar
johnf36
johnf36 is offline
No insulation here in the JCW Coupe , took delivery this week.
Old 04-04-2012, 02:04 PM
ditc's Avatar
ditc
ditc is offline
Ok. Very odd. My S was built about the same time as yours. This seems to be a difference between JCWs and S's. Like Indy said, N14 vs N18 differences again? I wonder.
With the insulation, air flow is probably non-existent. Though it looks like there are two small holes in the scoop.
Old 04-04-2012, 02:11 PM
texasmontego's Avatar
texasmontego
texasmontego is offline
Do you see a part number on the insulation? My 2007 gets terrible hot and this would definitely help.
Old 04-06-2012, 12:23 PM
ditc's Avatar
ditc
ditc is offline
Looks like my insulation has the following part number: 7276533
Old 04-06-2012, 12:41 PM
johnf36's Avatar
johnf36
johnf36 is offline
You guys with a S Coupe do you have holes in your hood vent?
Old 04-06-2012, 01:27 PM
DAVESTER's Avatar
DAVESTER
DAVESTER is offline
My S Coupe's scoop has every other vertical row of holes. 18 holes in all and I am one of the "have nots"
Old 04-06-2012, 02:22 PM
DavidB's Avatar
DavidB
DavidB is offline
It's shown on both the Cooper S and JCW Coupe models as of Feb 2012..
Old 04-06-2012, 04:27 PM
DAVESTER's Avatar
DAVESTER
DAVESTER is offline
Well, what the hell is 2 thru 10 for ?????????
Old 04-06-2012, 04:33 PM
DavidB's Avatar
DavidB
DavidB is offline
02 Sound insulat., splash wall, upper part
03 EXPANDING RIVET
04 Fastening elements
05 SOUND INSULATION F APRON
06 Noise insulation, wheelhousing, left
06 Noise insulation, wheelhousing, right
07 Acoustic foam
08 Acoustic foam
09 Acoustic foam
10 ???
Quick Reply: R58 Insulation under hood
