R59 Black Toffee
Old 09-03-2012, 04:43 PM
Slowride1's Avatar
Slowride1
Slowride1 is offline
BlueToy,
What a nice Roadster you have put together! And your pics WOW!
Thanks for the mod write up! Specially since I'm waiting on mine and have time to think about what I want to do.
  #202
Old 09-05-2012, 06:26 AM
Betty Boop's Avatar
Betty Boop
Betty Boop is offline
Beautiful roadster ! I love the black-toffee combination. And what amazing shots ! congratulations !
  #203
Old 09-05-2012, 06:44 PM
BlueToy's Avatar
BlueToy
BlueToy is offline
Originally Posted by Slowride1
BlueToy,
Thanks for the nice comments! Looking forward to seeing your new Roadster...you're gonna love it
Thank you
-Steven
  #204
Old 09-05-2012, 06:57 PM
BlueToy's Avatar
BlueToy
BlueToy is offline
NM Billet Catch Tank
I finally got around to getting my catch tank installed. As with all NM products, extremely well made, and their connectors made the install very simple. Nice knowing it's there keeping the intake track clean. Here's a look...
-Steven
  #205
Old 09-10-2012, 11:44 PM
severine68's Avatar
severine68
severine68 is offline
Beautiful roadster ! I love your seats !
  #206
Old 09-11-2012, 11:10 AM
FrannyB's Avatar
FrannyB
FrannyB is offline
Hi Steven,
That engine bay is unbelievable! So clean! You have how many miles? Looks great - better than new!
So what is the Catch Tank for? Is that off the crank case breather?
Thanks!
Franny
  #207
Old 09-11-2012, 04:29 PM
BlueToy's Avatar
BlueToy
BlueToy is offline
Originally Posted by FrannyB
Hi Steven,
Thanks!
Franny
Hi Franny,
I figured this would be the easiest way to explain it.
The last paragraph says it all
-Steven
  #208
Old 09-17-2012, 01:11 PM
severine68's Avatar
severine68
Originally Posted by BlueToy
After a week of time spent between Provo and Park City, it was time to move on. The plan was to head north through Idaho and on to Big Sky. However, looking at the map, I realize there is something I've always wanted to do, visit the Bonneville Salt Flats. It would mean traveling way out of the way, but in the end, so worth it! This place is surreal, strangely quiet, blinding during the noon day sun and not as smooth as you would think. If you look closely at the pics, you get an idea of the surface of the flats. Driving this was a dream come true for me.
The salt is very sticky, almost feels wet to the touch...
-Steven
Nice spot ! lovely car !
  #209
Old 09-17-2012, 01:25 PM
severine68's Avatar
severine68
do the short springs change the behaviour of your car ? isn't too harder ?
  #210
Old 09-17-2012, 02:03 PM
BlueToy's Avatar
BlueToy
BlueToy is offline
Hi Severine-
The springs actually ride very similar to stock, they are very compliant and feel more "planted". I think they give the wheel better articulation over bumps as well. What you give up is suspension travel, so really big bumps will have you on the bump stops. I am running them with the stock "sport" shocks/struts. I will be trying Koni Yellows soon. Also, if you plan on running lower springs, consider some kind of strut tower reinforcement.
-Steven
  #211
Old 09-24-2012, 05:24 PM
Slowride1's Avatar
Slowride1
BlueToy,
Why did you go back to the stock air intake?
Thanks.
  #212
Old 09-25-2012, 07:40 AM
BlueToy's Avatar
BlueToy
BlueToy is offline
BlueToy,
Thanks.
Here is what I found in regard to the intakes. Running the open filter NM, you get a lot more sound, and more power, especially at higher rpm. The downside, is on really warm days, in traffic, lots of heat, I noticed it didn't pull as hard off the bottom. Too much hot air. I found the factory intake with the Alta foam filter does a better job, makes more power in the low rpms. I definitely gave up some power at higher rpm, 5-6k range, but that is not where I do most of my driving. Hope this helps.
-Steven
  #213
Old 09-25-2012, 08:15 AM
Slowride1's Avatar
Slowride1
Here is what I found in regard to the intakes. Running the open filter NM, you get a lot more sound, and more power, especially at higher rpm. The downside, is on really warm days, in traffic, lots of heat, I noticed it didn't pull as hard of the bottom. Too much hot air. I found the factory intake with the Alta foam filter does a better job, makes more power in the low rpms. I definitely gave up some power at higher rpm, 5-6k range, but that is not where I do most of my driving. Hope this helps.
-Steven
Thanks, very helpful.
  #214
Old 09-25-2012, 08:38 AM
BlueToy's Avatar
BlueToy
BlueToy is offline
I think if I tracked the Roadster, i.e,. fast speeds and high rpm, one could really get the benefit of the open intake.
-Steven
  #215
Old 10-09-2012, 11:04 AM
Slowride1's Avatar
Slowride1
-Alta AP Stage 1 tune, a few tunes custom tweaked by Alta(Jeff). A quick word about the AP. This device is amazing at how it unlocks power and drivability, all the while delivering stock gas mileage numbers. Also, it allows me to carry multiple tunes, for different fuel situations. Example, in Chicago, I run the Stage 1 FMIC 92 octane tune. Out West, gas is 91 octane, so I would run the 91 octane FMIC.
Steven,
I didn't think anyone had a tune for the 12' and newer models, except for sending in your ECU to get reprogramed?
Thanks,
Paul
  #216
Old 10-09-2012, 09:06 PM
BlueToy's Avatar
BlueToy
BlueToy is offline
Steven,
Thanks,
Paul
Hi Paul,
The 2012 JCW has the N14 motor, which has had the AP tune available for a while. The 2012 "S" models run the new N18 with valvetronic, no AP available yet for that motor
-Steven
  #217
Old 10-10-2012, 11:06 AM
Slowride1's Avatar
Slowride1
Hi Paul,
-Steven
I was starting to get a "little" bit excited, but now that you say that I do believe I had read that in another thread. I have been so busy in the last few weeks reading old threads it is starting to run together .
Do you have enough miles on yours that you have checked the NM OCC? Was wondering if it might not hurt to put one on the N18 motor. Looks like from some of the early reviews it might still be needed.
Thanks,
Paul
  #218
Old 10-10-2012, 06:12 PM
BlueToy's Avatar
BlueToy
BlueToy is offline
Thanks,
Paul
Hi PAUL,
No fun hearing about the great performance aspects of the AP, and not having it available for the N18. I hope that changes for you soon.
In regards to the OCC, I have driven very few miles with it since the install. I'm out of town for 2 weeks on business, and will check it when I get home. I'll post my findings then.
-Steven
  #219
Old 10-25-2012, 03:48 PM
BlueToy's Avatar
BlueToy
BlueToy is offline
Koni Yellows
I made some changes to the suspension today, I replaced my factory "Sport" struts and shocks with Koni Yellows. I had been running the stock strut/shock set up with the NM Alpha springs. Lately, it felt as though I was blowing right through the stroke on the struts. I had read some really good reviews of the Yellows, especially when paired with the NM springs. This was also the recommendation from NM.
On the rack again
The Koni's made a huge difference, noticeable from the first few minutes behind the wheel. The ride feels firmer, but a lot more "planted". There is no noticeable dive/squat during braking and cornering is nearly dead flat. This combo reminds me a lot of the KW V2's I had on my R52. I'm currently running them at the middle setting, I'll continue to experiment with the settings to get a good feel what they are capable of.
I also switched out the run flats for a set of Conti DWS. I will see how these perform in the Chicago winter...
I spent a good part of the drive home using the same roads as my daily commute, taking in the differences over the rough sections and sharp expansion joints. The ride/control is so much better than my previous set up. The combination of the Koni's/NM Springs and Conti's made a huge difference in the feel and precision of the R59
-Steven
  #220
Old 10-25-2012, 07:01 PM
Slowride1's Avatar
Slowride1
Thanks for the update! They look good on there.
  #221
Old 10-25-2012, 07:53 PM
GEMSTER's Avatar
GEMSTER
GEMSTER is offline
Nice!
Im planning on getting the Conti DWS for my car as well.
  #222
Old 10-28-2012, 12:54 PM
hamptup's Avatar
hamptup
hamptup is offline
Originally Posted by Audiophile_Mark
Fantastic shots! You should go work for BMW as an advertising photographer.
+2 on that! What camera and lense? All tasteful mods too!
  #223
Old 10-28-2012, 02:32 PM
BlueToy's Avatar
BlueToy
BlueToy is offline
Thanks hamptup. Nikon D3, 24-70mm f2.8 lens
-Steven
  #224
Old 10-29-2012, 11:43 AM
BlueToy's Avatar
BlueToy
BlueToy is offline
New Pics
A couple of new ones...
-Steven
  #225
Old 11-03-2012, 06:12 AM
BlueToy's Avatar
BlueToy
BlueToy is offline
Fall morning...
-Steven
Quick Reply: R59 Black Toffee
