R59 Ringing the changes...
#151
Updated. it linked the wrong one.
#152
Ok, problem SOLVED! Had to splice into the wire that's already in pin 41 of the connector instead of inserting the terminal that is pre-fitted to the harness into pin 4. Here they are in the garage while I celebrated them actually working:
and here's a daytime picture of the lit lights:
There's almost no light off-axis. I'll see what they look like at night later and post a picture. I am however a bit concerned about the light output though. There's only a 3A fuse in the circuit so that means there's only a TOTAL of 36W maximum split between the two lamps. The pattern on the garage wall seems very concentrated though, so maybe there will be decent light at a distance. More later...
#154
#156
Those LED Rally lights look awesome. Get some shots at night from the cabin or garage door, before and after. Might want to cover up the headlights for the test wonder how bright on there own. You have so many lights now, its LED crazy on the front end.
#157
If you do this please come back and share your mounting strategy. If the lights are a good color match to the LED DRLs, I think they would look mighty fine located just inboard of the brake ducts.
#158
Would like to see those at night, really like how they match the DRL LED design.
http://www.ecstuning.com/Search/SiteSearch/63122288981/
and
http://www.ecstuning.com/Search/SiteSearch/63122338554/
and
#159
I'm thinking of recessing them a bit into the grille.
#160
Spiney,
I'm installing the rally lights and the bundle of ground wires that attaches to the post under the fuse box is not long enough, did you experience this?
Also my fuse holder came with a 15A fuse inserted and a 3A fuse in the bag. Am I suppose to replace the 15A with the 3A? The part where they talk about the fuses in the instructions is in german (that part wasn't translated).
#161
There was enough length for my case. I did have to play with how much wire to leave inside the car and how much to pull through to get it all to play nicely though.
#162
Not been many changes to report for a while, so it was about time I started on some. Just ordered English Oak door handles at a giveaway price from ECS Tuning. I wanted to get them before they disappeared, but I'm holding off on the dash pieces in the hope that the price drops a bit more!
#163
Thanks for the orders ! Its was a special limited quantity sale. Happens, but rare. Enjoy
#166
Awesome, looks great, the dash trims are almost a must with the door trims
#167
#168
Welcome again, the wood also adds a touch of class to a Mini or MINI
I have the RR Goodwood interior trim and it looks great.
#171
Pictures are not showing up for me? Cerenkov, can you see them ?
#172
#174
Hmmm.... I sort of cheated posting them. I hate the new upload screen so I tried to just use IMG/IMG tags directly. I'll try again above....
#175
Just an update, 63122288982 Black LED version are back in stock.
