R60 R60 vacuum pump assistance
Old 12-11-2019, 12:17 PM
7rhSon's Avatar
7rhSon
7rhSon is offline
So I'm curious about the vacuum pump on my car.. the main vacuum hose on the top creates the pull correct? And the bottom line leads to vacuum tank? I saw a guy on YouTube who had pulled some seafoam into the vacuum pump upper nozzle thinking he was pulling that stuff into the intake.. how does the entire system flow?
Old 12-11-2019, 01:51 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
The upper goes to the brake/clutch booster. the lower to the vacuum canister and from there it goes to the valve and then to the turbo.
Old 12-11-2019, 02:00 PM
7rhSon's Avatar
7rhSon
7rhSon is offline
So if that guy in the video was sucking seafoam into the upper outlet where was it going? The upper creates the vacuum for the booster
Old 12-11-2019, 08:58 PM
MrGrumpy's Avatar
MrGrumpy
MrGrumpy is offline
It was going into the brake booster or the vacuum lines and reservoir for the turbo wastegate control. That’s all there is. It doesn’t ever enter the intake at all. The variable valve system on these mean that they run at almost 0 vacuum on the intake. That’s the whole reason the vacuum pump is required, so there is vacuum supplied to the brake booster. Running the wastegate off of it is just a bonus.
If he was introducing it into the larger line, it more than likely filled up his brake booster vacuum reservoir nicely with sea foam!
Unfollow that dude and NEVER do what he does! Ha ha
The following 3 users liked this post by MrGrumpy:
ECSTuning (12-16-2019), MiniToBe (12-12-2019), SunBird (12-18-2019)
Old 12-13-2019, 04:29 PM
7rhSon's Avatar
7rhSon
7rhSon is offline
He was letting it suck into the vacuum pump itself via the top inlet
7rhSon
11-24-2019 10:27 AM
ig109
06-04-2019 09:15 PM
WookieNugget
05-19-2019 08:56 PM
bill12s
03-23-2017 02:57 AM
TimG517
11-29-2012 12:33 PM
Quick Reply: R60 R60 vacuum pump assistance
