F60 2011 Countryman S P0010 code help
Old 08-29-2020 | 08:52 AM
BMV_1's Avatar
BMV_1
Hey all, so I'm back with some more issues with my Countryman.
Background. Had the timing chain replaced and the FRM module replaced.
I'm now getting a P0010 code, which shows that there is an open circuit on the intake VANOS. Trying to figure out if there is a fuse, a bad wire, a loose connection, or if that is an indication of a bad solenoid. Any help would be greatly appreciated.
Old 08-29-2020 | 12:33 PM
njaremka's Avatar
njaremka
Alliance Member
Fault service plan involves checking the wiring, then replacing the solenoid valve:
https://bmwfault.codes/XMLDiagView?d...EAOAAyADAANAA=
If the connector looks good, I would just go ahead and replace the solenoid.
https://www.ecstuning.com/b-hamburg-...368610388~ham/
Old 08-29-2020 | 08:21 PM
navwizard's Avatar
navwizard
The intake Vanos and the exhaust Vanos should be the same part.
you could swap them and see if the fault stays on the intake, or follows the swap.
That will narrow down if it's the valve itself, or a wiring problem or something else.
cheers!
dan
The following 2 users liked this post by navwizard:
2014 MC (08-31-2020), ColtTheBolt (09-29-2021)
Carson01XJ
04-11-2019 08:15 AM
raybo1
02-26-2019 07:48 PM
arctic700
10-19-2018 01:55 PM
ChopperDan
02-20-2018 05:19 AM
Quick Reply: F60 2011 Countryman S P0010 code help
