R60 2012 R60 N18 oil filter housing.
Old 08-13-2022, 09:59 AM
Nix's Avatar
Nix
Nix is offline
Purchased the car used, 76,000 with the oil leak.
And now am tackling the leak. As I am reassembling the engine I noticed a small crack on the original housing. So ordered a replacement. Which brings me to my problem. The new housing is not fitted with a pressure switch.
is this normal? Should I just order another new one from a different vendor? Or should i just install it? If i do would that leave me in Limp Mide? Which then brings me to, how am I to know the pressure without the switch? Is there a MOD...
Old 08-13-2022, 11:39 AM
Nix's Avatar
Nix
Nix is offline
Oil filter housing
Also, I forgot to mention, on the new housing without the pressure switch the port although was molded on and shies signs of being removed and ground down. It was not fully ported into the housing.
Old 08-13-2022, 05:28 PM
Nix's Avatar
Nix
Nix is offline
Update
Did the install, obviously being there's no pressure switch, I don't get a oil pressure LED or code.
Originally i had received P0524 Low Oil Pressure, and since it had a oil leak that was obvious. And also P0014 VVT retarded (A). Replacing the Oil Filter Housing repaired the oil leak and I no longer have (A) retarded Mini.
But now I get I get P0597 "Thermostat Heater Control Circuit/Open". Followed with, stalled cold start, rough idle, hesitation at acceleration almost like it's misfiring. No other MIL or DTC appear.
I had already replaced the plugs and coil packs. Maybe the Mini is retarded.....
Old 08-14-2022, 04:46 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
Received 1,846 Likes on 1,472 Posts
Where did you get the replacement housing? The earlier N14 engines did not use an oil pressure sensor/switch on the housing, the later N18 engines do. Looks like the one that was sent to you is the earlier version. You’re going to want to get the proper housing and refit the sensor.
Old 08-14-2022, 03:42 PM
Nix's Avatar
Nix
Nix is offline
Re
Yeah got the housing off Amazon, obviously the fitment guide has some flaws....
And replacing this one is definitely on the to do list. But being this is my daily driver and i was in a pinch to get the job done before work monday i have to make due.
But as for the stall and hesitations i was getting, turned out to be the HPFP... odd there is no DTC for it...
And being i now have the P0597 thermostat code, the plan is to tackle the correct housing at the same time I replace the thermostat housing... next weekend.
But for a quick repair, as far as it goes with the firing everything is smooth again, minus not having the pressure switch. But it does seem to lack the take off acceleration.
Old 02-27-2023, 08:08 PM
NCapurata's Avatar
NCapurata
NCapurata is offline
If you don’t mind me asking, where on the filter housing did you find the slight crack? I have a 2013 CM All4S (Dec 2012 build ) and I’m dealing with a leak. Thought it was the oil filter housing seals/cooler seals, but I could not find a smoking gun when I removed it from the car. Base on the pattern, it looked like the return oil turbo line had failed, but it was not the case. The feed line did not look like it was leaking and was not loose, however the dark grime was heavy in the area of the feed lined and return like at the block/housing end.
did you end up putting the bay in service mode to do the work? Any pictures/pointers you could share re: service mode?
I appreciate your response.
Old 03-03-2023, 01:25 PM
ECSTuning is online now
Received 2,091 Likes on 1,865 Posts
Here are the correct parts:
N14 Engines:
https://www.ecstuning.com/b-genuine-...r/11428643749/
N18 engines.
https://www.ecstuning.com/b-genuine-...r/11428643745/
I have never seen one crack on the metal, its most of the time a the plastic cap cracks or there is a leak in the oil cooler or oil cooler to housing connection.
Oil filter housing DIY
https://www.northamericanmotoring.co...et-repair.html
The following 2 users liked this post by ECSTuning:
2014 MC (03-03-2023), NCapurata (03-03-2023)
idickers
03-10-2022 08:03 PM
VtecDrew
R55 :: Clubman Talk (2008+)
02-03-2022 11:41 AM
Nick Perez
10-14-2017 10:19 AM
phoxx47
12-16-2012 11:51 AM
meb
03-19-2007 02:46 PM
Quick Reply: R60 2012 R60 N18 oil filter housing.
