Chrome Trim Peeling after 7-days
Old 08-03-2011, 06:29 AM
NickChuck's Avatar
NickChuck
NickChuck is offline
I also have a Light White with peeling trim.
  #102
Old 08-03-2011, 06:40 AM
4GAZM's Avatar
4GAZM
4GAZM is offline
Originally Posted by Mark Bielick
That didn't take long:
So far, there are vehicle builds from March, April, May, and June, that have the defect. Additionally, new deliveries, and "new" replacement strips installed in July have failed. There is NO WAY this is related to a "bad Batch" of product from the vendor.
MINI simply screwed up the design.
Now, they need to fix it. Simply putting more of the same cr#p out in the field will not fix the problem.
If they do come up with a fix (like the usual 'metal over plastic' trim instead of cheap tape) they will need to replace all the trim on all the cars. I don't think the vehicle would look good a year or two from now with 1/2 the trim in tape, and 1/2 in metal.
Mark
exzacley! this will cost them a pretty penny! hence why companies hate big recalls but I bet you this will end that way. cost reduction is fine and if the part worked the way it was intended it nobody would notice it.... the problem is, this issue should have shown up during real world testing, but just seeing the full batch of countrymen MINI's all with peeling trim shows me this is more than just an isolated case. we had a cost reduction on a wiper motor, it was a small plastic grommet that cost under a buck but saved a few hundred thousand dollars over the product line, well someone didn’t do their home work and the testing was not done and failures soon happened. ended up costing over 8 million in warranty claims...... companies need to get it through their head that cost reduction is fine when the customer cannot see it, otherwise don’t touch it.......and if they do go through with it, it should be tested properly and gone through the motions... then bad PR like this won’t happen.. but it’s clearly made me wonder what else they cheapened out on which scares me into trusting the product...
[FONT=Calibri][SIZE=3] [/SIZE][/FONT]
  #103
Old 08-03-2011, 02:27 PM
ALL4TURBO's Avatar
ALL4TURBO
ALL4TURBO is offline
well said.
  #104
Old 08-04-2011, 11:40 AM
Alien88's Avatar
Alien88
Alien88 is offline
Glad I found this thread. The chrome strip on the bonnet is undersized and peeling on my Countryman. Production date of March on mine.
  #105
Old 08-05-2011, 08:42 PM
bbruins1's Avatar
bbruins1
bbruins1 is offline
Note from my MA
Hello Wayne,
This is going to be a permanent fix with new trims being available MINI is not releasing the same product number from the factory. And are going to issue a new replacement part. There is a delay until that part comes back into stock. All the way back to Germany. *Once we have a set and permanent fix for you I will give you a call.
  #106
Old 08-08-2011, 08:06 AM
trowski99's Avatar
trowski99
trowski99 is offline
A few more details...what my MA shared:
To: Service Managers, Shop Foremen, and Technicians
Subject: 2011 MINI Countryman (R60) Chrome Trim Peeling
We are aware of the situation regarding the exterior chrome trim pieces peeling. This is due to the excessive heat and humidity we have experienced in recent months. The replacement parts have not been effective.
A Special Task Force was established in Germany last month to find the root cause and provide a repair solution. We have learned the affected production range is from 3/2011 to present.
We apologize for the inconvenience and ask for your patience while we investigate this problem and provide a solution.
Technical Service
  #107
Old 08-11-2011, 09:41 PM
Tahoe Ed's Avatar
Tahoe Ed
Tahoe Ed is offline
Just picked up my CS CM S ALL4 from the dealer today. Both rear quarter trim pieces were already damaged. I spoke to the service manager and since neither of us had a clue when a permanent fix will be available, he is ordering two new pieces. Thanks to the good folks here, I knew what to look for when I picked up the car!!!
  #108
Old 08-12-2011, 03:54 AM
Larrypss's Avatar
Larrypss
Larrypss is offline
this thread has answered alot of questions before my trip to the dealer. I would be happy if they would peel my chrome and then black it out. I have a red CM s with a white top. I just bought it a week ago.
  #109
Old 08-12-2011, 07:40 AM
MC_Sean's Avatar
MC_Sean
MC_Sean is offline
Add me to the list. 3/11 build date. Noticed chrome tape peeling from trim on the boot less than a week after delivery. At first glance looked dented. May have been there all along. Chrome tape around windshield is also shrinking to expose plastic underneath, but is not peeling off. Mine is Pure Orange with Black roof/mirrors/wheels. I think the blacked out look is the way to go for me. Although, I'm going to alert my MA of the problem so he can add me to the list to get the updated parts when/if they arrive. If it's the same old crappy plastic covered with chrome tape, I'll be disappointed. I was very surprised to see how cheap they went on this trim. I love my CMS, but the build quality and overall quality of materials is sub-standard compared to my 2004 MC40 (R.I.P.). Lots of little rattles and annoyances. Luckily I've got the pop and barble of the sport mode to drown most of it out. (-; Still love this car though!
  #110
Old 08-12-2011, 07:50 AM
Justmenmymini's Avatar
Justmenmymini
Justmenmymini is offline
MC_Sean, we have the same color combo and I've thought of blacking out the beltline as a permanent fix also. But there's the part of me that wants this fixed right. I don't want Mini saying that it was my fault when I applied the tape.
So far I have no peeling but I'm watching and waiting, knowing it's inevitable. Thanks to everyone who has contributed to this thread. I can't imagine finding this flaw and not being prepared.
  #111
Old 08-12-2011, 08:15 AM
KevinAndJohn's Avatar
KevinAndJohn
KevinAndJohn is offline
Luckily we caught ours before delivery and notified our Motoring Advisor. they're on the lookout for the fix, as both the sales manager and dealership owner have Countrymen with the exact same affliction. As soon as anyone has any info on the permanent fix, (esp. a TSB # or part #'s) please notify the group so that we can all reach out to our dealerships right away... THX all!
  #112
Old 08-12-2011, 08:31 AM
MC_Sean's Avatar
MC_Sean
MC_Sean is offline
Yeah, I'm a little hesitant to do the black-out mod without some assurance that they won't use this as an excuse to not honor the warranty claim. Ideally, I'd like to go ahead and black it out. Then, when the permanent fix is available, simply get the parts from them so I would be able to put them on down the road if I wanted to put it back to stock. I doubt they would do it though.
  #113
Old 08-12-2011, 01:57 PM
ALL4TURBO's Avatar
ALL4TURBO
I blacked mine out after I went to the dealer and showed him that it was peeling. They replaced the peeling pieces and then I blacked them out. Now they are peeling. I called the dealer and he just put me on the list for replacement parts when they become available. I doubt they can fight it much. Its a super wide spread problem. But if your worried, do what I did and visit the dealer so they can send the claim. Then go peel the chrome and black it out. It looks way better IMO..
  #114
Old 08-19-2011, 07:05 PM
stevendoll's Avatar
stevendoll
stevendoll is offline
I was in the dealer looking at a a CM, and saw this BS trim on the car. The early R50/R53s had some bugs, but wow, this is really out there in terms of poor build quality. I pray that this is not a sign of things to come.
  #115
Old 08-19-2011, 07:41 PM
zekemini#3's Avatar
zekemini#3
zekemini#3 is offline
Caved and let my CM put the temporary fix on last weekend the 13th, because my car looked so bad. They replaced the six failing trim pieces out of 10. Its the 19th, 2 pieces have shrunk, one of the short ones has a bubble on the end. Ugh. I know its temporary, but this is ridiculous on a new car.
I got a MINI service satisfaction survey and while my service department is great I said I wanted corporate MINI phone call. When I talked to MINI about it, dude tells me that MINI was not aware of this problem with the Countryman...um, wth? Needless to say I come off of some words I probably shouldn't have. I have made 3 calls to corporate MINI about this trim issue myself. I know I'm a nobody but d#&n. Every Countryman on Roadshow MINIs lot in Memphis has this issue. EVERYONE. The one on the showroom floor has pieces on it that are 1/4 inch short. MINI should be ashamed.
Needless to say, this not a problem that is going to be fixed anytime soon.
  #116
Old 08-19-2011, 07:42 PM
minikari's Avatar
minikari
minikari is offline
I just posted this on another thread, but I'll copy and paste the update about the chrome trim here as well;
So, good news and bad news. I guess all the pre-March trim was from a factory in japan...that got destroyed in the tsunami. After that, they commisioned another company to do the chrome trim from scratch....and they effed it up. They know the problem which is good, but the bad news is that factory in Japan is still unoperable, so even though rumors have been flying around about october good chrome, I doubt it is going to haopen. You can get red or black beltline tape at outmotoring.com in the meantime.
  #117
Old 08-19-2011, 09:21 PM
bradrulz's Avatar
bradrulz
bradrulz is offline
Mini told me the exact same time after I called them twice. First time was after the initial failure and the 2nd was after all of them were replaced and started having issue within about a week. Each time I called they said they were unaware of any issue like this with the Countryman.
  #118
Old 08-20-2011, 07:19 AM
Mark Bielick's Avatar
Mark Bielick
Mark Bielick is offline
minikari,
Are you speculating about the cause being a move from a supplier in Japan, to a supplier in Europe? Or do you have something from MINI or BMW stating that is what occured?
I find it hard to believe that a company like BMW would change sourcing in such a manner without going through a new supplier product testing program. I have run a manufacturing operation that supplied castings to BMW in the past, and I can tell you that no supplier would be allowed to produce product without going through vigorous test program before approval. Maybe MINI short changed their own new supplier development program, and brought these guys on without testing? If so, then the responsibility is all MINI's.
Mark
  #119
Old 08-20-2011, 07:24 AM
ALL4TURBO's Avatar
ALL4TURBO
My story is the same... You know the dealers know... I've gone black.. Looks good, but I recommend peeling any chrome off that even shows weakness before blacking out.. I have a few pieces now that have peeled that I have to replace. Its never ending!
  #120
Old 08-28-2011, 06:17 PM
swaginwagon's Avatar
swaginwagon
swaginwagon is offline
Add me to the list. I will update you tomorrow on the new state of this issue.
  #121
Old 08-29-2011, 06:08 AM
Funkzilla's Avatar
Funkzilla
Funkzilla is offline
Took delivery Saturday, noticed as soon as we got home...called. I was told by my MA they have even halted building some 2012's until they get the issue solved.
  #122
Old 08-29-2011, 01:53 PM
ALIENLOVE's Avatar
ALIENLOVE
ALIENLOVE is offline
I have the same problem on my hood trim now and took my CM to my dealer and they said MINI is aware of the problem and will be fixed soon but my question is will they replace only peeled trim or all of them on the car? I dont want to take my car 10 times for each trim seperately.
  #123
Old 08-29-2011, 03:22 PM
Miniblue2's Avatar
Miniblue2
Miniblue2 is offline
I'm 100-percent sure all the trim on every Countryman produced with the defective trim will be replaced. Cut off is sometime in March. I don't know if the 2012's will have the same problem, hope the fix is in before they are produced.
Mine was a December build and I don't expect the trim to be replaced.
Bill
  #124
Old 08-31-2011, 07:27 AM
timster121's Avatar
timster121
timster121 is offline
Noticed the same problem on my CM this afternoon. Trim around the windshield is peeling like crazy.
I was going to wait until I take it in for the first maintenance to mention it (the Mini dealer isn't exactly convenient for me to get to).
Wonder if there's any merit in calling and mentioning it before I bring it in?
  #125
Old 08-31-2011, 07:37 AM
callahan00's Avatar
callahan00
callahan00 is offline
since you are not close to your dealercall them ASAP. The replacemenmt is on back order so it will take around 4 to 6 weeks [maybe longer] to get the replacement. Closely inspect ALL the chrome beltline to get an inventory of the parts your dealer will need to order. Look for shrinkage on the ends. As soon as it starts shrinking it will soon start to peel. We have peeling on the right D pillar and shrinkage on the windshield, left D pillar and both passenger doors. The windshield is starting to loosen. You will not be able to just show up on a maint. visit and have them replace it while you are there unless they have already ordered the pieces. It is back ordered and they are not stocking this right now. Our MA said it takes about an hour to replace.
Quick Reply: Chrome Trim Peeling after 7-days
