Joystick Problem
Joystick Problem
We have had our CM for three months now. I noticed from the very beginning that when you depress the joystick you have to press it down much harder than I what I would think to be normal...otherwise nothing happens and it's as if you did not press it at all. Anyone else have the same complaint/ observation? I searched the forum for similar complaints and the only thing I could find was an R56 owner whose joystick would get stuck in the depressed position. The dealer lubed it and solved the issue. Thanks in advance for your input.
I've got the same issue in my 2012 CM. Need to "press with authority" to make a selection.
My wife has a 2012 R57 w/ Connected, but hers seems to act as you'd expect: gentle press & selection is made.
I've not made mention of this to service since I've gotten used to the press and I'm more concerned they'd break additional stuff vs. just fix what I've got now if an attempt was made. That and it doesn't bug me since I'm used to it now.
UncDeo
11-04-2019 05:08 AM
Navigation & Audio Portable Navigation XL Wiring
mikeandtricie
09-04-2015 02:42 PM
mimaal
09-04-2015 10:09 AM
09-02-2015 10:05 AM
