Rock hit my windshield
2012 Countryman S All4 with 119,000 miles and no more warranty. Driving behind a dump truck (really dumb of me) doing 70+ the interstate and a rock flew back.
There is a dime-sized area where both outside and inside surfaces are smooth to the touch but the middle is shattered. Should a replace it? Repair it? or Ignore it?
Took the car to a local glass repair place. They only want a few hundred to replace it. Or should I bring it to the dealer?
Any danger it can get worse while driving fast? We drive cross country (North - South) often.
Nothing but problems with this car and yet I still love it. Go figure.
Much appreciated!
Much appreciated!
I assume you have comprehensive insurance on your auto policy. Weigh the cost of replacement vs your deductible and make a decision. Personally, when i had to replace mine a couple of years ago, i went thru insurance and took it back to the dealer for replacement as i didn't want an aftermarket windshield with the potential for sub-standard fit causing any water leakage into MINI's fragile electronics.
My '06 S has been peppered with rock chips (PO drove exclusively on the freeway). I had the most damaged area fixed for $50. After it was fixed, the shop said if I wanted a new windshield, it would be $150 (scam? Maybe!).
If you have the money, I'd have it replaced as soon as possible. If you're on a budget, get the major areas repaired (it'll still look bad but it shouldn't develop any cracks).
Our Mini's have a very firm suspension setup and over time, that rock chip will translate into a large crack across your windshield.
I was recently rear ended at a stop sign and had a huge claim on my insurance. Not sure I want to put in another or they are going to jack my rates.
I drive on horrible roads all the time. Can certainly afford to fix or replace the windshield. Calling Mini Dealer now to see what they charge.
Ugh - that 59mpg Hyundai Hybrid is looking pretty good. Would love to get to 150,000 first.
I've had three windshields replaced on my 06 R50 by safelite...nothing substandard about them. They warranty their work and the only reason I've had to get the windshields replaced is where I live there are a lot of trucks on the roads...hazards of living in the south and in the country. $450 seems a bit high...Oh...zero deductible with my insurance...I just call and the insurance replaces it.
The near vertical angle of the MINI windshield is what makes a stone collision so damaging. An independent glass shop in my area has replaced 4 on my '06 R52 and one on my co-pilot's '15 R60 all at $100 deductible. There has never been a problem with any of them except once a small 'leak' at the top that created a werewolf howl at high speed. He took care of it in 5 minutes and no charge. A good glass man is sure to be in your area if you seek him out.
1. As mentioned few dealers or even body shops do glass work ... they farm it out.
2. I've had glass replaced in many of my cars, including MINI over the last 40 years and most of the time by SAFELITE. I had a problem with SAFELITE ONE time and one phone call had them right back out with all new parts and a total redo .... no questions, just apologies. My insurance routes a glass claim directly to SAFELITE .... you can override if you like. (I also appreciate that SAFELITE is a large company with many locations and performance MAY vary ..... but a complaint to corporate would bring action IF there was a local issue, IMO)
3. Glass is typically covered under 'comprehensive' (altho some companies require a completely separate "rider".) If you are covered under 'comp' and carry a deductible, especially a significant deductible, I suggest you call and ask what your rate change would be to change that deduct' to ZERO. Rate tables for comp' are WAY different from collision theft. I carried $250 deduct on comp' for 4 cars and asked "what's the rate change for a zero deduct' on comp?" It was WAY under $100 a year TOTAL. Having just changed a front glass and paid the $250 ........ duh ......
4. I was recently rear ended at a stop sign and had a huge claim on my insurance. Not sure I want to put in another or they are going to jack my rates. Should fall under completely different elements of your insurance ... but THAT depends on the quality of your insurance company ..... IMO if you are afraid to file a claim ... shop for new insurance.
5. Safelite will usually do the work at your house / work / or darn near anyplace else ....
6. You don't mention what state you are in, but in some states ... Florida is one .... if your glass is 'covered by insurance' - {you have comp'} no matter what deductible - insurance must replace the front glass and charge NO deductible. In other words, if you live in FL and have comp' which covers your glass and have a $250 deductible, insurance must replace broken front glass at ZERO cost to you ...... state insurance laws .... 'safety item'. I believe FL is not UNIQUE in this.
