Oil spot on bottom of MT. Couple Qs
Attached is a picture of the bottom of the manual transmission in my 14 CMS4. I noticed this oil a few weeks ago, shortly after buying it and cleaned area up really good. Noticed today that there is a small amount of oil at A, where halves/shells/elements of clutch housing meet. Though I was unsure previously, the two holes at B do not seem to be where oil is coming from. Oil does not appear to be running down back side of transmission--checked with mirror. I have not jacked car up and crawled under yet due to lack of time. It doesn't appear that this would be the logical path of oil spilled from changing the oil filter, but I will admit I am new to Minis.
Car recently had a new clutch installed by prior owner at dealership and I am hoping that a leaking rear main seal was not ignored. However, it seems that if rear main seal was leaking, it would leak out the two vent holes before it seeped out between shell halves. Clutch seems to be working well. Sorry about crappy pic. Hoping the collective NAM wisdom can guide me.
Let 'er rip.
Let 'er rip.
I will look at oil housing gasket and oil control valve, though I really don't see any creek/stream/trickle running down outside of bell housing at all.
I dusted area with baby powder and took another pic to show things better. You can't see the rear vent hole, but it looks wetter. Front vent hole is obviously dry. "Eye" spots don't connect to anything and must be where I rubbed powder off. Gotta pull that exhaust bracket off, so I can look directly at rear vent sometime...
semibreve42
10-02-2015 09:06 AM
Interior/Exterior Bottom metal looking insert for bottom grill?? looks really
EliteCooperS
02-20-2003 04:27 PM
