2013 MINI Cooper Countryman S Cylinder 1 Misfire After Spark Plug & Coil Replaced
Hey y'all. I have a 2013 MINI Cooper Countryman S that is throwing a P0301 Cylinder 1 Misfire code. 3 months ago I replaced all spark plugs and coils when all four cylinders were misfiring. The car was running fine and is now acting up again, and I only use premium gas.
Here's the breakdown of all codes thrown according to BlueDriver:
----Confirmed Trouble Codes Scan Report----
1 Confirmed Trouble Codes Trouble Codes:
1. P0301
Cylinder 1 Misfire Detected
----Pending Trouble Codes Scan Report----
1 Pending Trouble Codes Trouble Codes:
1. P0301
----Permanent Trouble Codes Scan Report----
1 Permanent Trouble Codes Trouble Codes:
1. P0301
----Advanced Crash and Safety Management Codes Scan Report----
3 Advanced Crash and Safety Management Trouble Codes:
1. 93C3
Status: History • OC3
2. 943A
Status: History • CIS-Matte CIS IQ values out of range
3. 943D
Status: History • CIS-Matte CIS Internal HW Error because of humidity
----Engine Codes Scan Report----
8 Engine Trouble Codes:
1. 2EFE
Status: History • DFES DTCM.DFC TASRmin C - intake air temperature past throttle valve actuator
2. 2EFF
Status: History • Misfiring, cylinder 1: detected
3. 2EE0
Status: History • Misfiring, several cylinder: shutdown injection
4. 2EE4
Status: History • Misfiring, cylinder 1: shutdown injection
5. 2EE2
Status: History • map thermostat, input signal
6. 2EE6
Status: History • Elektric fan, triggering
7. 2EE1
Status: History • coolant medium pressure sensor
8. 2EE5
Also, here's the freeze frame values for reference:
PID : Description : Value
04 : Calculated Engine Load Value : 85.9 %
05 : Engine Coolant Temperature : 185 °F
06 : Short Term Fuel Trim Bank 1 : 12.5 %
07 : Long Term Fuel Trim Bank 1 : -0.8 %
0B : Intake Manifold Absolute Pressure : 47.8 inHg
0C : Engine RPM : 3463 rpm
0D : Vehicle Speed : 48 MPH
0E : Timing Advance for #1 cylinder : 6.0 °
0F : Intake Air Temperature : 39 °F
10 : Mass Air Flow Rate : 10.20 lb/min
11 : Absolute Throttle Position : 85.9 %
1F : Run Time Since Engine Start : 467 seconds
23 : Fuel Rail Pressure : 1735 PSI
2E : Commanded Evaporative Purge : 0.0 %
2F : Fuel Level Input : 72.5 %
33 : Barometric Pressure : 30 inHg
42 : Control Module Voltage : 14.701 V
43 : Absolute Load Value : 150.6 %
44 : Commanded Equivalence Ratio : 0.953 λ
45 : Relative Throttle Position : 74.9 %
46 : Ambient Air Temperature : 37 °F
47 : Absolute Throttle Position B : 85.9 %
49 : Accelerator Pedal Position D : 56.1 %
4A : Accelerator Pedal Position E : 27.8 %
4C : Commanded Throttle Actuator : 90.2 %
51 : Fuel Type : 0 N/A
Any thoughts or suggestions?
1. P0301
1. P0301
1. P0301
1. 93C3
2. 943A
3. 943D
1. 2EFE
2. 2EFF
3. 2EE0
4. 2EE4
5. 2EE2
6. 2EE6
7. 2EE1
8. 2EE5
HI, you don't state if you used OEM or aftermarket plugs and coils. I have a 2013 and a 2106 R60S. I had issues just like you with the 2013. I used aftermarket Coils. I finally went for OEM and haven't had an issue since. Cant explain it...Coils with the same spec's should work and continue to work but they didn't.
My thought and just a guess is that if you run a scangauge or similar and look at your voltage. These cars jump quite a bit. BMW turns the alternators on and off a lot to help with fuel mileage. Maybe the wide swing on voltage from in my case 13.8 to as high as 15 is too much for the coils. I have not had any other voltage related issues with either car, they both have the same voltage swings but could the extra 1 or 2 volts on the coils be too much? Just my thought.
highpressuresteam
05-27-2014 12:41 PM
2003minicooper
05-03-2012 03:57 PM
