R61 :: Paceman Talk R61 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
R61 Thickest tire possible
Old 02-21-2014 | 11:19 AM
RVNZ-R61's Avatar
RVNZ-R61
Hey guys, does anyone know what the thickest tire I can put on a stock paceman without having to put a lift kit on? I'm really not a fan of the run flats and want something more comfortable.
Thanks for any input!
Chris
Old 02-21-2014 | 12:56 PM
KiwiRob's Avatar
KiwiRob
If you wanted a comfortable car why buy a MINI? Drop a wheel size or 2, if you're running 18's go down to 16's, the higher profile sidewall should improve things but it's never going to be a smooth riding car, that's not the MINI way.
Old 02-21-2014 | 02:26 PM
bjcarter2's Avatar
bjcarter2
Just getting off of the R/Fs will improve your ride.
Knowing what you have now for tires and wheel size will help others to make suggestions though. Just sayin'. :D
Old 02-21-2014 | 05:31 PM
bmwr606's Avatar
bmwr606
my sall4 has the factory sport suspension (10 mm lower than standard)
i am running 225/50R18 michelin pilot super sport summer tires - 26.9 inch od and 205/70R16 dunlop grandtrek sj6 winter tires - 27.3 inch od
the stock 225.45R18 tire is 25.9 inch od
Old 02-22-2014 | 10:43 PM
RVNZ-R61's Avatar
RVNZ-R61
Thanks for the response guys.
Just to be clear, I love my car. One of the main reasons I bought a MINI is because of the ride quality and tight suspension - just not a fan of run flats feeling a little more of the bumps than I like to feel.
I have stock suspension on a front wheel drive R61S with the turbo fan 18" wheels
Old 02-22-2014 | 10:56 PM
bmwr606's Avatar
bmwr606
here you go, Chris
tirerack.com has 42 different 225/50R18 tires
http://www.tirerack.com/tires/TireSe...50&diameter=18
scott
Old 02-26-2014 | 09:54 PM
gchin's Avatar
gchin
Look at tirerack for all season touring tires.
Let us know what tires you get and how it feels, ok?
Old 03-04-2014 | 12:27 AM
HorseWithNoName's Avatar
HorseWithNoName
Chris
I am running 245 45 18 in Bridgestone S04 Poles on my Paceman the ride and grip is awesome, it really transformed the look and stance of the vehicle. Another great choice would be the Michelin Pilot Super Sport in a 235 45 18, have a friend running them on his JCW Countryman and said it improved the handling and ride quality tremendously.
If you have the lower sport suspension I would do the Michelin Pilot Super Sport in a 235 45 18.
Old 03-04-2014 | 12:01 PM
bmwr606's Avatar
bmwr606
are you running aftermarket wheels or spacers on the oem wheels? 245/45R18s rubbed on the front struts on my 2012 all4 with sport suspension, 235/45R18 had only about 1/8 inch clearance
i have a local independant tire shop where i test fit various sized tires before purchasing the 225/50R18 michelin PSS
the same shop helped me figure out i could run 205/70R16 winter tires on the mini euro oem alloy wheels
Old 03-04-2014 | 04:41 PM
bmwr606's Avatar
bmwr606
18
Originally Posted by rodhot
fitting non stock sizes only takes a little research on line, tire rack posts detailed specs, them an others will help with correct fitments, they use a plus or minus sizing system, its all explained on tirerack.com. unless you have huge brakes big wheels and rubberband tire are mostly bling, in the end its your $$$
tirerack is not the be-all end-all of knowledge, i use tirerack and agree they have lots of good info
i was told the 205/70R16 winter tires would not fit, and that 205/65R16 would not fit ... be they do ... checked by test fitting at a friendly independant local tire store before purchase
at the same time, test fit 245/45R18s and they rub the front strut on my 2012 all4 with sport suspension ... 235/45R18 had only 1/8 inch clearance to the strut, 225/50R18 had same clearance as stock to the strut and OD wise they clear fine
Old 03-05-2014 | 08:12 AM
HorseWithNoName
I have stock rims with no spacers or clearance issues on my 2013 Paceman S fwd running the Bridgestone Potenza S-04 Pole Position in 245 45 18. We rarely get snow but they performed better than I expected from a maximum Performance Summer tire. (see photo below)
I do know that actual tire size differs between brands and models, link to tires, click on specs tab to see the numbers.
http://www.tirerack.com/tires/tires....omCompare1=yes
Attached Thumbnails Thickest tire possible-paceman.jpg   Thickest tire possible-wp_20140121_14_44_47_smart-1-.jpg
Old 03-05-2014 | 08:42 AM
bmwr606's Avatar
bmwr606
mine is an all4 with sport suspension ... wonder what is different? the shock strut itself or the hub to strut distance or maybe the hub itself? ... there is no way a 245/45R18 will fit my CM with stock wheel and no spacers
EDIT: my small local independant shop's house brand is hankook, so that is the brand of tire we test fit ... don't recall which exact tire, but it was a "performance" tire due to the section height
Old 03-05-2014 | 08:53 AM
HorseWithNoName
The front of the R60 and R61 should be the same, although I have the sport package I didn't opt for the lowered sport suspension. I'm thinking the shorter sport suspension decreases the angle of the shock or the sport suspension shocks are bigger in diameter or maybe a combo of the two.
Old 10-19-2024 | 06:39 AM
Bucky99's Avatar
Bucky99
16" wheels will fit!? I had no idea I feel robbed
Old 10-22-2024 | 07:05 AM
Yep here:
https://www.northamericanmotoring.co...ountryman.html
Waszak
10-21-2017 05:55 PM
dpike
09-12-2015 08:19 AM
Tires, Wheels & Brakes
09-09-2015 11:08 AM
Ntety
09-02-2015 08:39 PM
Quick Reply: R61 Thickest tire possible
