Road Racing Discussion Interested in taking your MINI road racing? Find out what you need to do to get your MINI ready!
Team Onasled and M7
Old 07-13-2007, 09:08 AM
onasled's Avatar
onasled
onasled is offline
Thanks Tony.
There is an abundance of room now under the hood, so what comes forward of the TB is still in my head only. Just finished up the radiator plumbing and I'm quite happy with that so far.
Dumped the Green ...
  #477
Old 07-13-2007, 09:12 AM
onasled's Avatar
onasled
onasled is offline
Guess where the air is coming from for the IC?
Also the coil will be replaced and relocted as soon as we get her up and running again. Gunna add some real 'fire'power.
  #478
Old 07-13-2007, 01:34 PM
maxmini's Avatar
maxmini
maxmini is offline
Originally Posted by onasled
Don Pardo tell me what I've won I recognized that plastic end piece way too fast. Messed with too many of them not to LOL
Randy
M7 Tuning
  #479
Old 07-13-2007, 01:44 PM
Dr Obnxs's Avatar
Dr Obnxs
Dr Obnxs is offline
Nice little intake pipe...
you may want to wrap that as well, it's right behind the radiator and will get heat from the radiator. Since you're going all the way you might want to do that one too.
Matt
  #480
Old 07-13-2007, 06:32 PM
Partsman's Avatar
Partsman
Partsman is offline
Legion_of_Doom
Greg, this pic here...
...did you guys just weld a nipple onto the stock connection flange that the water pump outlet mates up to?
  #481
Old 07-13-2007, 06:37 PM
onasled's Avatar
onasled
onasled is offline
Yes. I turned the pipe from some solid aluminum round and then just welded it to that stock peice.
  #482
Old 07-13-2007, 06:52 PM
Partsman's Avatar
Partsman
Partsman is offline
Legion_of_Doom
Nice, then that's how i'll be doing mine when I get the electric pump.
  #483
Old 07-13-2007, 07:12 PM
Partsman's Avatar
Partsman
Partsman is offline
Legion_of_Doom
Ok, one more...
...is the top hose connection on your radiator the outlet?
That new nipple you made would normally be the inlet to the block from the pump.
After looking at this pic some more...
...it looks like your pump is pumping into the lower rad hose connection and UP through the core and out to the block. yes/no?
  #484
Old 07-14-2007, 09:22 AM
onasled's Avatar
onasled
onasled is offline
Ok, one more...
You are right in the first part. Thanks for pointing that out, though I think we would have caught on. Not really sure it makes a diff as there is no more thermostat, ... but I have redirected the hoses anyway this morning. Also tapping into the block in at least one more spot, if not three for other water inputs.
Pump is pumping out from the bottom.
Old 07-14-2007, 10:31 AM
Partsman's Avatar
Partsman
Partsman is offline
Legion_of_Doom
I just wasn't sure if you were keeping the stock flow direction.
You're right though, it may not matter if there is no thermostat, are you at least going to run a water outlet restrictor plate?
  #486
Old 07-31-2007, 03:06 PM
onasled's Avatar
onasled
onasled is offline
..... sorry that all the pics are down. This is in result to that stolen CC. It's about impossible to to get the new payment to Tripod.
http://video.google.com/videoplay?do...70044857025796
  #487
Old 07-31-2007, 03:34 PM
snid's Avatar
snid
snid is offline
It's alive! And it sounds like it revs up really quickly.
  #488
Old 07-31-2007, 06:06 PM
newbs49's Avatar
newbs49
newbs49 is offline
Where's the dam video. Sound, no pic.
  #489
Old 08-01-2007, 08:47 AM
MarkC's Avatar
MarkC
MarkC is offline
Getting closer........
Greg when do you think you will have your car ready for the track?? I do hope it is in the near future.
Mark
  #490
Old 08-01-2007, 05:33 PM
onasled's Avatar
onasled
onasled is offline
No video Larry, just sound. No more pics from this point on. The next pics I post will be of the done deal.
Mark, soon...... I hope.
For the life of me, I can't get the clutch slave cylinder blead
Help....
  #491
Old 08-01-2007, 06:11 PM
Partsman's Avatar
Partsman
Partsman is offline
Legion_of_Doom
Help....
How have you tried to bleed it so far?
There is a special tool to keep the piston from moving, I may be able to borrow it from work. I think a block of wood may accomplish the same thing.
You could also try to pull the fluid through the cylinder.
  #492
Old 08-01-2007, 06:32 PM
onasled's Avatar
onasled
onasled is offline
I compressed the cyliner with a clamp and both sucked the fluid through it and also used the pedal pumping method. Both worked well, but still a dead pedal with no more then about 1/16" movement. I've always had issues with the Mini slave. Even broke one a few years back and just ended up having a dealer do it.
Man, I've built this racecar from every screw up and that damm thing still has me baffled.
  #493
Old 08-01-2007, 06:42 PM
newbs49's Avatar
newbs49
newbs49 is offline
Greg, if Joaquin can get the tool you may be better off.
  #494
Old 08-01-2007, 07:20 PM
Partsman's Avatar
Partsman
Partsman is offline
Legion_of_Doom
Are you using the factory master cylinder/reservoir? or a separate one for the clutch?
I know you have aftermarket(Tilton?) pedals, did you just rig them to work with the stock cylinders?
  #495
Old 08-01-2007, 07:54 PM
onasled's Avatar
onasled
onasled is offline
All Tilton. Only the slave is factory. I don't think it's that but I could be wrong. This is the same problem I had when it was all stock. I just don't think I understand how it should be done.
Joaquin, think about coming up wit the tool and give me a hand... ?
  #496
Old 08-01-2007, 07:59 PM
Partsman's Avatar
Partsman
Partsman is offline
Legion_of_Doom
The earliest I could get there would be Sunday. Let me see if I can get the tool and i'll let you know tomorrow.
  #497
Old 08-02-2007, 07:57 AM
///ACS330Ci's Avatar
///ACS330Ci
///ACS330Ci is offline
  #498
Old 08-04-2007, 04:30 PM
TonyB's Avatar
TonyB
TonyB is offline
Greg, it sounds like you are so close! I'm sure it's plenty frustrating... I'm guessing that you got some help by now, at least I hope so... You have a huge following here, and the suspense has built quite a bit!
  #499
Old 08-06-2007, 09:10 AM
RED FURY's Avatar
RED FURY
RED FURY is offline
PICTURES please .... The suspense is KILING US !!!
  #500
Old 08-06-2007, 06:35 PM
newbs49's Avatar
newbs49
newbs49 is offline
Phil
I believe Greg is waiting til the car is complete. I believe he has an event he's shooting for.
Quick Reply: Team Onasled and M7
