Pedals and Heal-Toeing
All,
I took delivery of a 2006 MCS w LSD a couple of weeks ago. It's a great handling car but the juxtapostion of throttle and brake pedal is less than ideal for heal towing. The biggest problem is that the brake pedal is too high! Have you found a way to lower the brake actuation point? How else have you dealt with this issue?
Many thanks,
Bruce S
Many thanks,
Bruce S
All,
Many thanks,
Bruce S
Many thanks,
Bruce S
When I first got my MINI, I used a pair of sneakers that had a particularly wide width across the ball of my foot; this helped bridge the height difference between the two pedals. However, the shoe wasn't flexible enough and lacked my preferred "pedal feel". I define "pedal feel" as being able to lightly touch the brake pedal and feel the right edge of the pedal's face under my foot.
I then tried some Piloti Spyders and the world became a beautiful place again. For my tastes, they are appropriately wide across the ball of the foot, but are very flexible and transmit just enough "feel". The Pilotis also have a wrap-around edge on the side of the shoe that contacts the throttle when heel-toeing.
Borrow someone's Pilotis and see if that makes any difference.
Also, somewhere online I saw aftermarket pedals "designed" for heel-toeing. And, while they did not address the height difference you speak about, they were designed with additional surfaces on the right side of the brake pedal and on the left side of the throttle. They would not be to my taste, however, as I feel the extra material may be a bit dangerous in some situations.
Theo
on
The installation of my Ultimate Pedals helped with that problem and others:
https://www.northamericanmotoring.co...2&postcount=19
Hit the brakes harder?
I guess the best advice is to just get used to it. I can heel-toe my MINI pretty well, now. I tried driving a friends Miata, which is supposed to be great for heel-toe shifting, and I couldn't do it in that car because I was used to my car.
On the street, I usually use the side - to - side method described above. On the track, that would sometimes fail me. I'd get my foot too far over to the brake side and not be able to reach the gas with the right side of my foot. So, on the track I've switched to using the ball of the foot on the brake, and the heel on the gas... right foot angled like this \
Different people find different methods best...
if you wanna see some check out my gallery...
Best of luck
I seem to be able to do the "side to side" style with my speedcats, and they are THIN.
-Brian
I totally second this. My amazing g/f got me some spyders just before we went to the Monterey Historics. And it was a big difference. Heal & toeing is so much easier with those shoes. Plus they are so comfortable, I have no problem standing around all day in them @ the track. Get some, you won't be bummed at the decision.
Best of luck
Best of luck
_Dave_
Here is a fairly informative article about heel-toeing courtesy of Audiworld.com in Canada:
http://forums.audiworld.com/canada/msgs/22677.phtml
Theo
Theo
That's a great article. I also find the MINI to be real easy to heel-toe. Originally, it wasn't but when the brake fluid were flushed (by the dealer), the pedal became softer and allowed much easier heel-toe. I'd still like solid brakes though... Now that I'm only driving a few times a week, I'm loosing consistency on my double clutches and heel-toe downshifts.
drrigg
05-27-2022 03:31 AM
eliseo1981
11-02-2015 11:24 AM
sevin
09-24-2015 05:00 AM
