F55/F56 NM boost tap/Gauge
NM boost tap/Gauge
Hey y'all!
So I ordered the nm boost tap and a gauge to install in the mini. Anyone got some good recommendations on where to run the hose??? Plus I'm thinking about modding one of the A/C vents to hold the gauge... But looking at the dash, it's gonna be harder then I expected to access the vents. If someone can give me some insight that would be great!
You're better off just getting the gauge pods from cravenspeed. Much easier. As for running, I went along the front just underneath the engine cover then under the intake, made a small hole into the battery space and then ran it into the car using the clutch cable grommet hole. It's the same hole used to run the burger tuning jb4.
Note, be sure to lightly grease all the o-rings as well as when the hose attaches to the tap. I had a boost leak the first time.
I'll put up a picture of mine but if you look for me on Instagram (minif56nyc) you'll see how it turned out. Good luck!
Thank you marcopolo!!!!
Thanks so much for your reply!!!! Hey would it be to much for u to post some pics of where you ran the line and of the gauge pod???lol basically your set up! What kind of grease did u use? Silicon? And what exactly did u grease? Thank you tons for your help Marco Polo! I need as much help as I can!
Hey y'all!
The F56 does not really make any vacuum in the intake manifold which is where you are getting your readings from. I believe the N18 engines from the R5x gen are the same way.
Don't know about the B46/48, but I do know my '07 with the N14 pulled enough vacuum to activate my forge blowoff/diverter valve. Don't have a clue what the threshold was for that though. Could have just been anything less than boost. All I know is it worked like a champ.
