Cvt not showing any select letter in claster
hello everybody
I have my Mini Cooper 2002 r50
the transmission not changing speed fine
after rpm 5 it's change speed
and there's something different
before showed EP and know after I replaced transmission its same before problem
But no EP no XP no P
i replaced cvt module
and relay
I checked all fuses
I replaced engine wiring harness
i have fault code : measuring speed sensor
see photo
and relay
I checked all fuses
see photo
When the transmission was rebuilt was it run through the gears properly? I had a problem with my CVT and after replacing the fluid and adding a serum from oilextreme.com it worked a lot better but I needed to run through all of the gears. On this site in the DIY section there is a reference on how to go through the gears properly. Not sure if this would help but that's my 2 sense.
