Old 04-18-2017, 09:21 AM
MiniRoadstah's Avatar
MiniRoadstah
MiniRoadstah is offline
Originally Posted by -=gRay rAvEn=-
Added painted GP front upper grille to finish off the body kit. Vinyl wrapped 3 center grille slats with gloss black vinyl, installed a vintage M7 scoop in gloss black, added a silver GP scoop decal, topped with set of new/old stock
pure silver side mirror covers that were take offs in 2002...
Nice job... you need to pull that puppy out into the light and let us see it from more angles. Just one picture? Need way more!
  #18752
Old 04-18-2017, 09:58 AM
newman4333's Avatar
newman4333
newman4333 is offline
Originally Posted by DneprDave
FRM? What is that?
Foot well control module or Foot well relay module depending who you talk to. Mine started killing my battery so I replaced the battery thinking it was bad (wasn't) then everything went completely nuts.
  #18753
Old 04-19-2017, 02:13 PM
burley's Avatar
burley
burley is offline
Quick clean up of the engine bay...
  #18754
Old 04-19-2017, 04:08 PM
cristo's Avatar
cristo
cristo is offline
Getting both windows and a tie rod (seized adjustment threads) replaced.
  #18755
Old 04-20-2017, 11:27 AM
JABowders's Avatar
JABowders
JABowders is offline
Mmmmm, so clean. <Smiley Face>
I just drove #24 Yesterday and I have #211 out to day... just enjoying the cars.
Motor On!
  #18756
Old 04-20-2017, 04:38 PM
mini coop's Avatar
mini coop
mini coop is offline
Thanks, yes we do! They still have the same part number they just updated it with the 2008+ JCW updated logo design. I have one of the old design logos also. You can see it in that thread. Yea, they have no logo or the newer jcw logo.
https://www.northamericanmotoring.co...used-baby.html
MINI also just NLA the Alcantara wheel and the leather one for the gen1 MINI has been NLA for a while.
https://www.northamericanmotoring.co...ion-issue.html
Its sad to see them go , that's why I tell people if we have it, buy it. Because next year it might be NLA.
Did I see in the installation instructions that the JCW brake handle does not lock on like the stock brake handle?
  #18757
Old 04-21-2017, 01:25 PM
Received 2,023 Likes on 1,817 Posts
Yea, some people use double sided tape or wrap the e-brake metal rod with tape and slide it on. MINI has some glue they apply that's thick.
PDF here
  #18758
Old 04-22-2017, 07:35 PM
mattkosem's Avatar
mattkosem
mattkosem is offline
Added a swaybar and links. Love it!
  #18759
Old 04-23-2017, 01:39 PM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
Received 1,161 Likes on 907 Posts
Living in upstate NY I deal with rusted everything. Here's something I found that works to keep tie rods from seizing up. I loosen the bolt that holds the tie rod tight, spray some oil into the slot in the tie rod where the treads are, and coat the slot/threads with anti seize. With a couple of wrenches turn the tie rod adjuster a half turn one way, then a full turn the other way and back a half turn to work the anti seize into the thread. As long as you end up where you started, your alignment will still be good. And the tie rod won't seize up.
For me, today was replace a brake caliper and do an oil change; Motul 5-40, which I haven't used before. I also plan to have Blackstone test the oil to see how hard the turbo and being out on the track are on the oil.
  #18760
Old 04-23-2017, 03:08 PM
pizzaman09's Avatar
pizzaman09
pizzaman09 is offline
Gave the Mini it's first spring cleaning.
  #18761
Old 04-23-2017, 05:25 PM
Tio Barry's Avatar
Tio Barry
Tio Barry is offline
Good job, Eddie. The path to making your car last a long time is rigorous.
  #18762
Old 04-29-2017, 05:15 PM
mattkosem's Avatar
mattkosem
New wheels and tires and a wash/clay/seal.
  #18763
Old 04-30-2017, 11:34 AM
Zephyr1's Avatar
Zephyr1
Zephyr1 is offline
Summer shoes
Took off winter runflats, put on summer rubber:
In the winter I appreciate the potential safety and convenience of runflats. I don't even want to think about dealing with a flat in freezing rain and blowing snow. In the summer though.... dropping 8 lbs per corner between rims and non-RF rubber - wow, every spring the revelation anew of how much zippier Tess is with summer shoes!
  #18764
Old 04-30-2017, 03:26 PM
Thumper Simpson's Avatar
Thumper Simpson
Thumper Simpson is offline
Finished filling fluids, went for test drive with new PS pump. No power steering at all after installing NEW, not rebuilt, pump. NOT HAPPY!
  #18765
Old 04-30-2017, 03:43 PM
CooperSAZ is offline
Gave him a bath today.
  #18766
Old 04-30-2017, 04:11 PM
burley's Avatar
burley
burley is offline
what year Cooper? This was a recall for some model years.
  #18767
Old 04-30-2017, 07:09 PM
rebonz's Avatar
rebonz
rebonz is offline
Buffed out a couple of keyed marks on my drivers door. Gotta love humanity.
  #18768
Old 05-01-2017, 08:20 PM
pkunk's Avatar
pkunk
pkunk is offline
Replaced the serpentine belt in just over an hour. 126200 miles and no history of it ever being replaced. I've driven it for 16K and decided now's the time. It was pretty cracked & brittle. The little tool from ebay was just the ticket!
  #18769
Old 05-02-2017, 09:50 AM
pmsummer's Avatar
pmsummer
pmsummer is offline
Not today, but all last week... with a dozen other MINIs.
  #18770
Old 05-03-2017, 09:13 AM
MiniRoadstah
Great Ride! And a paper map! Well done!
  #18771
Old 05-03-2017, 10:41 AM
pmsummer's Avatar
pmsummer
pmsummer is offline
2600 miles in 8 days.
  #18772
Old 05-03-2017, 11:12 AM
ST3ALTHPSYCH0's Avatar
ST3ALTHPSYCH0
ST3ALTHPSYCH0 is offline
Ordered strut mounts, new Bilstein B4s and drew up a template for a strut plate protector. Just need to pick up some 1/8" plate and spend a few minutes w/ the plasma torch.
  #18773
Old 05-04-2017, 10:25 AM
newman4333's Avatar
newman4333
Changed the oil for the first time since I've owned it.
  #18774
Old 05-04-2017, 10:35 AM
Haag75's Avatar
Haag75
Haag75 is offline
I sadly burned out my stock turbo this last weekend racing. However I had already talked myself into upgrading it last month with a K04 GT Dominator. Bummer is i'm going to miss my race at COTA before it will get here
  #18775
Old 05-06-2017, 06:02 PM
Hit this today...
Quick Reply: What did you do to your mini today?
