Navigation & Audio R56 full active build
Hello everyone. I acquired a new MINI and set to work on the stereo immediately! It's a base N12 automatic cooper but it gets 31 mpg and will be very pleasant and pretty pretty by the time I'm done. I'm so psyched about the stereo. I finally get to play with a fully active set up!
The components are mostly left-overs from other projects so the cost is essentially just wiring, a bezel and nick-nacks.
Pioneer DEH 80PRS headunit (single din with time alignment and other active processing)
Dynaudio 6.5 component set run without crossovers
Alpine PDX 4.150 for the components
Infinity Basslink subwoofer
No rear speakers at all.
Running independent wires from the amplifier to the door speakers was very challenging. You have to run everything passed the door-jam connector. I accomplished this by cutting an ear off the connector and cursing a lot. Managed to run 14ga through eventually. (Unfortunately I lost pictures of this process).
Disassembled the right side interior to run 8ga to the sub and 4ga to the component amp. What a mess.
Grounded the sub amp to a common ground in the right rear. The component amp and headunit will share a ground near the passenger seat rail.
The door speakers need adapter plates to mount. I fabricated some out of soft 1/4" cutting boards. (Great material to have handy btw. Pick up a dozen next time you're at IKEA!)
The outer shape is just the stock speaker shape. I traced around it crudely and cut away with a jig saw. The inner took some trial and error with the jig saw but turned out perfect.
MIminiclubman (06-25-2017)
Thanks for looking! Yeah, but it's as frustrating as fun at times. Anyone who's had these interiors apart can relate.
I had to remove the center console to install the CD player and bezel but it worked out. Routing the RCA cables the last leg was a challenge as well; I ended up removing the secret compartment and going up to the right of that.
Bluetooth mic installed and looking good.
Radio is in and looks quite nice. Losing the door chime was a surprise but not one I'm sad about. FM reception is horrible. I need to hard wire a switched power line to the diversity module, I guess.
Tuning has begun and I've managed a pretty strong image around the center of the windshield, especially female vocals (and surprisingly, kick drums).
