F55/F56 Looked into Retrofitting Rear Fogs
Old 08-27-2017, 08:01 PM
TVPostSound's Avatar
TVPostSound
TVPostSound is offline
Originally Posted by pw1114
Go to Headunit. Then Expert Mode. Then Steps 2 and 3.
Found it, not in head unit.
As I mentioned earlier, its showing coding that is incorrect when reading.
For instance tire temperature with TPMS shows inactive, when is is active. I had it coded by a guy with E-Sys.
Shows DRL in unknown.
Im afraid of what else it reads wrong, and recodes it wrong. I can't look at _every_ parameter.
  #102
Old 08-28-2017, 12:16 AM
pw1114's Avatar
pw1114
pw1114 is offline
Sorry. You're right. It's BDC i think. I don't know why I said head unit.
  #103
Old 08-28-2017, 08:22 AM
TVPostSound
Right, but what do you think of it reading my existing coding incorrectly
  #104
Old 08-29-2017, 06:07 PM
pw1114's Avatar
pw1114
pw1114 is offline
Are you using the Vgate iCar 2 Wi-Fi OBD adapter?
  #105
Old 08-29-2017, 06:57 PM
TVPostSound
Yup, only one that will work with Bimmercode.
Waiting for response from developer before I try to code.
  #106
Old 09-10-2017, 04:09 PM
TVPostSound
Originally Posted by spacecadet
As I just posted in the coding thread, you need to do the following - not just buying the switch, but also using e-sys to enable the feature in the body domain controller (BDC)
2) 3068, NSL_Verbaut = Verbaut
3)
3064 Mapping_Nebelschlussl_L_output = nsl_l
3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht
3064 Mapping_Nebelschlussl_R_output = nsl_l
3064 Mapping_Nebelschlussl_R_Function = nebelschlusslicht
These options enable the correct outputs on the BDC to activate the lights. You could choose to have only one light on if you wished
I believe line 3 is incorrect, should it not be this:
3064 Mapping_Nebelschlussl_R_output = nsl_r
  #107
Old 09-11-2017, 08:13 PM
David9962000's Avatar
David9962000
David9962000 is offline
How do you install the euro switch? Do you pull on the panel?
  #108
Old 09-11-2017, 08:15 PM
TVPostSound
Pull the side panel first, one screw, then pull the under panel, 6 retainer clips.
Switch has tabs, one connector.
  #109
Old 09-15-2017, 08:55 AM
TVPostSound
Anyone else notice the latest Bimmercode update no longer sees the BDC.
All I get from the developer is the same response overtime I ask a question.
It will be fixed in the next revision. HA!!
EDIT
Due to the new mandatory recode by MINI, Stephan at Bimmercode needs to rewrite his software, as MINI made it harder to access.
EDIT
  #110
Old 09-15-2017, 01:00 PM
pw1114's Avatar
pw1114
pw1114 is offline
EDIT
EDIT
what is the new mandatory recode?
  #111
Old 09-15-2017, 02:15 PM
TVPostSound
Its an internal recall. Any MINI from 2013 to 2017 that goes into a dealer gets this:
The following 2 users liked this post by TVPostSound:
bratling (05-05-2018), pw1114 (09-15-2017)
  #112
Old 09-18-2017, 09:02 AM
ECSTuning is offline
Received 2,100 Likes on 1,873 Posts
Can you repost that a bit bigger, i cannot see all of it. Thanks for posting that up.
  #113
Old 09-18-2017, 09:11 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
TVPostSound (09-18-2017)
  #114
Old 09-18-2017, 09:33 AM
TVPostSound
You sound like my wife!!!
12-23-2015 10:36 AM
dyeLucky
09-11-2015 10:41 AM
SamtheSham152
R57 :: Cabrio Talk (2009+)
08-14-2015 07:01 PM
StealthR53
08-08-2015 10:59 AM
dyeLucky
08-07-2015 07:10 AM
Quick Reply: F55/F56 Looked into Retrofitting Rear Fogs
