Old 09-25-2017, 07:03 AM
njaremka's Avatar
njaremka
njaremka is offline
Received 1,852 Likes on 1,476 Posts
Changed out the gear oil in the transmission. Used Redline MTL. Noticed MUCH smoother shifting right away.
Thinking about a short shifter now. Any thoughts on the add on shift adapters, as opposed to the full replacement from Cravenspeed?
  #19077
Old 09-25-2017, 07:08 AM
nqr31467's Avatar
nqr31467
nqr31467 is offline
Installed LED backup lights. Definitely brighter than before.
ECSTuning (09-27-2017)
  #19078
Old 09-25-2017, 07:16 AM
gumbedamit's Avatar
gumbedamit
gumbedamit is offline
1.) Changed rear brakes to EBC Reds, Noticed the rear passenger brake pads had excessive wear compared to the other 3 wheels. The other pads didn't even need to be changed, looked like I just put them on. I bled all 4 wheels and flushed the brake lines.
2.) Changed the CV boots, simple job until I hit the bearing and all the little roller pin bearings flew all over the place....LOL With my eagle eyes, I was able to find all the little pin bearings and put them back into their case, (retainer ring).
3.) Change the Valve Cover/Spark Plug seal gaskets.
On my way to work this morning, I got the EML light, will check the codes when I get home later today. Should be nothing, I hope........
  #19079
Old 09-25-2017, 08:06 AM
Loyal242's Avatar
Loyal242
Loyal242 is offline
Installed an aluminum coolant tank. The OE plastic one was leaking. 181,300 miles.
  #19080
Old 09-25-2017, 08:24 AM
walk0080's Avatar
walk0080
walk0080 is offline
  #19081
Old 09-25-2017, 08:28 AM
mdaz75's Avatar
mdaz75
mdaz75 is offline
This morning I dropped off the little bastard at the body shop. A couple weeks ago I had a kayak accident that dented and scratched up the roof, ripped off the antenna assembly and tore up the rain gutters.
  #19082
Old 09-26-2017, 07:39 PM
sani's Avatar
sani
sani is offline
Did an intercooler inlet muffler delete with a diy kit I made at work.
sani
  #19083
Old 09-26-2017, 09:50 PM
Bnourai's Avatar
Bnourai
Bnourai is offline
As a wise men said pics and info or it did not happen.lol
Ben
  #19084
Old 09-27-2017, 03:22 AM
cristo's Avatar
cristo
cristo is offline
Put on a Sphereology ****.
Originally ordered the Orbature, but it turned out to be on long back order.
470g compared to the stock **** at 180g - smoother shifting, easy install.
Looks nice. Delrin shell won't be too hot or too cold in summer/winter.
  #19085
Old 09-27-2017, 03:23 AM
cristo's Avatar
cristo
cristo is offline
Put on a Sphereology **** (Raceseng).
Attached Thumbnails What did you do to your mini today?-sphereology-delrin-black-gate-1_5.jpg
  #19086
Old 09-27-2017, 04:26 AM
njaremka's Avatar
njaremka
njaremka is offline
Nice. I have the Contour now, and I’m looking at picking up a Sphereology as an alternate.
  #19087
Old 09-27-2017, 04:41 AM
sani's Avatar
sani
sani is offline
Ben
Here you go ;-)
sani
Adrian Valverde (09-28-2017)
  #19088
Old 09-27-2017, 07:18 AM
ECSTuning is offline
Received 2,100 Likes on 1,873 Posts
"Got rid of the awful run flat tires and made a video about it on the Oregon coast!"
Those run flats changed out make a huge difference.
  #19089
Old 09-27-2017, 01:00 PM
beken's Avatar
beken
beken is offline
Crossed a mileage milestone. Afraid of which major component is going to be first to break.
  #19090
Old 09-27-2017, 01:13 PM
That is impressive! Is the entire drivetrain original?
  #19091
Old 09-28-2017, 05:40 AM
Adrian Valverde's Avatar
Adrian Valverde
Adrian Valverde is offline
This is pretty awesome. Which MINI do you drive? What have you done to it so far?
Hope it drives another 250k for you
  #19092
Old 09-29-2017, 11:25 AM
beken's Avatar
beken
beken is offline
Clutch and front bushings are the only things replaced so far.
also the 15% reduction pulley, and 22mm rear swaybar, Madness CAI, and spark plugs.
Everything else on the drive train is original from the factory. Built 07/14 as a 2015 early build LCI (facelifted) model.
  #19093
Old 09-29-2017, 11:36 AM
godskid's Avatar
godskid
godskid is offline
Wow - 235,000 miles and it's an (early) 2015? You drive it quite a lot! I thought you were talking about an older vehicle.
  #19094
Old 09-30-2017, 05:09 PM
sani's Avatar
sani
sani is offline
Scored a set of 16" OZ Superleggera's to use for winter and track for $200 total!
sani
  #19095
Old 09-30-2017, 05:40 PM
Promius's Avatar
Promius
Promius is offline
Got myself a JCW exhaust. Painted the tips blacked. Installed it today with help from friends. Removed the red viper stripes. Loving the clean and simple look
  #19096
Old 09-30-2017, 07:36 PM
CSP's Avatar
CSP
CSP is offline
And your gas mileage went back up also.
Is this true?
  #19097
Old 09-30-2017, 07:37 PM
CSP's Avatar
CSP
CSP is offline
sani
nice score
sani (10-02-2017)
  #19098
Old 10-01-2017, 09:53 PM
squawSkiBum's Avatar
squawSkiBum
squawSkiBum is offline
Washed it, drained and refilled the coolant, and cleaned/re-oiled the filter element on my ECS intake.
Once all that was done, it was such a nice day I decided to drive CA-84 over the hill to the coast and back. There was traffic so I couldn't have too much fun but most people were being polite and using the turnouts to let faster traffic by. It was a nice mellow cruise on the way out, on the way back I ended up behind two motorcycles who were not the usual "donorcycle" riders with a death wish. In fact they were S-L-O-W. There was a new Camaro behind me who was barely keeping up. Finally I found a turn out with good sight lines behind it, so I pulled off and let the Camaro by. I waited until I saw traffic coming up behind me, then was able to have a spirited drive up to Skyline, catching the Camaro at the stop by Alice's. Not pushing hard, just good fun.
  #19099
Old 10-02-2017, 06:15 PM
Bnourai's Avatar
Bnourai
Bnourai is offline
Here you go ;-)
sani
Nice work.
  #19100
Old 10-02-2017, 06:24 PM
Bnourai's Avatar
Bnourai
Bnourai is offline
Love the color of your car
ECSTuning (10-09-2017)
Quick Reply: What did you do to your mini today?
