xenon headlights
xenon headlights
I am tired of having to replace my xenon headlight housings and having my local mechanic pin my headlights in place every time the plastic piece that attaches them to the auto leveling motor breaks. Currently both of my headlight housings have broken auto leveling systems and I need to replace them ASAP as my headlights currently are pointing at the ground about 10ft in front of my car. I found these online and they are supposed to be as close as you can get to aftermarket OEM headlight housings, without paying the premium price for the ones direct from MINI. It's debatable weather they have the auto leveling feature, but I would prefer they don't so I am not in this mess again. So, does anyone have inexperience with this problem or have purchased these headlights? Also if it helps these are for a 2005 R52 Mini Cooper S Cabrio.
Hella’s are the OEM supplier for the headlights so they should be identical to your current headlights. Also, auto leveling is required by the DOT for xenons so any DOT certified replacement would have them.
Does the ball and socket keep popping loose inside your headlights? Slamming the hood or hitting really bad bumps and pot holes usually is the cause for them to pop loose. After your mechanic fixes them, how long are they lasting before they point down again?
We have these options if you need stock: Hellas are OEM for the 7/2004+ xenon. They are the same just dont have the MINI logo on them.
https://www.northamericanmotoring.co...eadlights.html
I have seen this happen from slamming the hood hard. I have seen them pop back in, but if they ball holder is broken on both them they will need replacing.
Another option: https://www.northamericanmotoring.co...installed.html
Also, on CARiD's website they are selling the Hella replacements for $474.05 each as opposed to the $800+ that most other sites, dealerships, and mechanics want for each housing. Do you know of any other sites that may have the housings for a similar price? Because CARiD is currently out of stock of the driver's side housings.
Side note; my MINI is an '05 made after July 2004, so pre 7/2004 housings are not something I'm looking for. And I'm not too concerned about staying perfectly stock, just as close as I can without spending a ridiculous amount of money.
The driver side for hella is now NLA, Hella directly told us this and the passenger side will most likely go nla here soon. Think MINI bought up all the hella stock. The " AL " automotive lighting ( oe for certain BMW applications) and Magneti Marelli (aslo OE for some MINI) have coverage where Hella is not making them anymore. We have them linked above.
schenck7
06-21-2012 05:27 PM
vladlos
Electrical
05-10-2011 09:26 PM
vettestripes
09-28-2010 10:32 PM
Interior/Exterior Will 02-04' style xenon washers fit on 05-06' xenon headlights?
IceManMCS
10-09-2009 02:30 PM
