F55/F56 My rear seat delete
My rear seat delete
My 15 MCS has the cargo package (lid and net) so the Sneed delete kit would not work for me. For the money, I think that the Sneed kit is a good deal but I needed something that was level as we stock up weekly with water, beers, birdseed, etc. let alone luggage. I made one for under $40 and about 2.5 hours of time. this includes wood, adhesive and polyester felt. If one has a sabre saw, cardboard for template, rasp/sandpaper, wood glue and screws, it is fairly easy and straight forward. I'll post the sequence pictures if somebody wants to see them
IrishCooper (09-05-2022)
seat delete
Remove seat. Back unlatches, bottom pulls up from front. Note front round horizontal tabs-use later to slide nylon hold downs through.
Make template. Use compass couple of inches open and trace side. Can use one side and copy to other-there are the same. and hold cardboard level with back. Narrower than 4' so overlap and tape template. Little narrower than 2' wide so trim width.
Transfer to plywood. Cut out sides and width with fine blade sabre saw. Do not forget back notch.
Cut board to length. Rip it to make rear brace same total height as cargo lid.
Remove seat back (latches) and bottom(pulls up from front).
Materials:
2' x 4' sheet plywood by .75" (17mm) Home Depot $16.97
.75" x 1.5" x 6' select pine Home Depot 4.72
1 yard black polyester felt Jo Ann fabrics $6.99/yd.
1 can Elmer's Multi purpose spray adhesive (or any brand) Hobby lobby $6.99
8 1" sheet rock screws (or any wood screw)
Wood glue. Scrap cardboard 2' x 4' taped. Compass or stick with pencil.
CallMeRacerB (09-17-2019)
seat delete 2
Temp fit. Measure when flush with back. Rasp or sand (soften) edges.
Measure, glue and screw front board. Be sure to just clear behind front seat tabs for fit. They should be exposed but will not be seen. Rip and glue back pieces.
Spray and glue felt. I also stapled back with 1/4" staples.
Slip in from front doors. Can screw down along back. D rings can be used in front. I added an eye ring through rear seat holder.
I bought a large door map from Lowes when I bought the car. Trimmed back corners round and front cup holder. Nothing slides much.
OK but shipping and handling will be $900 more
Seriously, it only took me 3 hours. If you know somebody, locally, that is a woodworker, they could probably make it in a hour.
You could also make a template from the seats when they are folded down-maybe adding a little to the sides. The key to making it flat is to shim the panel after you cut it, maybe by stacking washers, using a straight edge for flatness and then measure the washers.
Regards.
Regards.
Sorry I realize this is an old thread but -
Just out of curiosity: what did you do with the seats after the delete? I want to do something similar but don't have storage for the seats at home once they're out. Are they worth trying to sell or is it just scrap at that point?
WilliNilli (08-26-2022)
Interior/Exterior Rear Seat Delete Kit? Interested?
stylin99
06-01-2014 06:32 PM
Interior/Exterior Searching for rear seat delete that is flat to rear of car
cevans
12-26-2011 05:22 AM
Marwan
09-02-2008 07:59 AM
Interior/Exterior Rear Seat Delete: Save over 40 lbs!!
Tateae
06-10-2005 09:50 AM
