Bimmercode App
#51
Marco.
but again, this is only with e-sys. if there is a way bimmercode app does it, i wouldn't know how to.
good luck! fyi, it's very hard to break something, so don't be too concerned.
Not running, just hit the toggle switch once so the radio, gauges, heater etc... power up.
I shut off all of that before I code. Also, keep the door open. It will keep the car from sleep mode. When we flashed our ECUs the instructions said to keep the door open and plug in the driver's seatbelt. Id do that if you are coding a lot of things.
Also, I coded some things, started the car up and drove about 15-20mins to get more charge in the battery then coded the rest of the stuff I wanted in there.
The following 3 users liked this post by Mini_Vinnie:
I tried to code the rear fog lights and got them to work. (in expert mode)
Then I tried under 'Air Conditioning' to 'remember last settings'. (in standard mode)
Now I can't turn off the air conditioning. I can raise it but not turn it off. It also keeps the rear defroster on but it keeps blinking. And the auto start/off doesn't activate on stopping. The light works but not the function.
I tried to restore but get an error. I just get a red light on the app next to air conditioning.
I also disconnected the battery but it didn't effect anything.
I email their customer support so waiting on a response.
Has anyone else ran into this problem?
I can't hard code it anymore since my laptops (mac&win) stopped connecting to my car.
#70
#71
Bought bimmercode app today also and started coding. Already experienced with esys but laptop is too old for new esys premium launcher. So bimmercode and Bluetooth 4.0 vgate pro adapter bought.
Have a countryman phev 2017. With updated software in jan 2018. Bimmercode saw almost nothing. After the update it sees most ecu’s now. But i get a lot of errors when i want to read an ecu. More people have this issue?
Also kombi ecu can’t be coded in mine.
#72
That’s odd. When I first got BimmerCode several months ago, it was missing features for my 18 Clubman but that was because some modules changed. With the latest update, it finally has everything I was looking for. Was able to finally turn off the over sensitive passenger seatbelt warning today.
#74
#75
