F55/F56 JCW Grill on to Non JCW
Yes...
If you like the red grille stripe, you could have it wrapped. Just make sure you choose a "red" that matches the Chili Red of the JCW should you decide to add more red accents to the car.
I had mine wrapped and it looked fine until I had my brake ducts painted Chili Red through my dealer. Then the grille stripe looked too orange in comparison. Wound up trying to get the cross piece pulled off and painted, but destroyed the grille in the process. So I replaced w/ a JCW grille
FunToMini (03-29-2018)
So, it is molded into the grill, but the badge itself can very easily be removed via the threaded nuts on the inside of the grill. I used one of the go badges to cover up the portion of the grill where the badge went (it is slightly recessed and flat as opposed to the rest of the grill texture). It looks great overall and isn't very noticeable at all. It is if you are being very nit-picky about it, but the overall change was way worth it compared to the Justa grill.
Most people have been doing it.
https://www.northamericanmotoring.co...rd-cooper.html
You can see the threaded nut but you will have a little surfboard outline.
kylerogowski
10-19-2013 11:10 AM
IzzyG
04-22-2013 02:29 AM
Interior/Exterior Installed black grill trim and JCW grill.
richardsperry
05-25-2011 06:29 PM
toolazyforalogin
06-30-2008 07:24 PM
Zooooom
Want to Buy - All Other Items (archive)
03-08-2008 06:25 PM
